Import tracks with overlay question.
has someone found a way to import a new reel into a super-session with overlay/match tracks without wiping all automation on all the following reels? The only work-around I´ve found is to import the reel after the last one (using map TC to... in the import window) and then moving the elements up using alt-H. Or import to new track and move up. It would really be great if we could add a "from to" limitation for overlay/match tracks. Or make PT recognize a selection in the timeline for the import. Thanks, Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Import tracks with overlay question.
Not behind my set at the moment, but you can do it by modifying the session setup of the new reel before you import. Limit the timecode range of the "to be imported session", save and import into the supersession.
How do you limit the TC-range of a session? Never heard of that before.
Thanks, Frank.
Had a look, but I think you're right, you can't... I remember finding the solution for importing reel 2 with match track without wiping automation of reel 1 etc, but that only works if you get the new reels sequentially, it still wipes whatever is after it...
So yeah, feature request.... |
There is a way.
I think, though I haven't done it in a while, if you import with the last reel first you will retain the automation. |
You can only import stuff behind the last element of you time-line and then move that earlier using alt-H or cut/paste. (see original posting) Frank.
I wish you could actually overlay reel 3 right where is belongs without wiping reels 4-6´s automation or jumping through hoops. Frank.
))) LEX |
BUG: 10.1.3 crashes when undoing track-import with overlay | Frank Kruse | Post - Surround - Video | 4 | 05-17-2012 01:55 AM |
PT10: Import tracks with overlay+match tracks not working | Frank Kruse | Post - Surround - Video | 3 | 12-02-2011 09:06 AM |
Automation Track Overlay | Legion6789 | Pro Tools 9 | 0 | 03-20-2011 07:28 AM |
Keyboard Overlay For PC | DrDub | General Discussion | 2 | 05-20-2006 02:04 PM |
how do you overlay a midi track? | meatygoodness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-28-2004 04:58 AM |
