Old 11-05-2007, 01:43 AM
Sandager Sandager is offline
Default double notes when sustaining?
Hello all -
I don't know if this has been up before, but I couldn't find anything, so here goes:
When I record piano with sustain pedal via MIDI, ProTools "doubles" my notes?
It records the actual thing I play + the same in very short notes.
This makes the playback "die" or after only a split second and not the full duration of the chord.
I have experienced this on both the big HD system but also on my small Mbox2 mini.
Am I doing anything wrong? I want to record both the sustain action and the notes I play.
(it takes time to draw the automation afterwards)
I have ProTools LE and Korg/Nord MIDI devices.
Thanks in advance.
Morten Sandager
I think this should have gone in the Windows forum, sorry.
Old 11-07-2007, 12:57 AM
Dylex Dylex is offline
Default Re: double notes when sustaining?
I'm experiencing the exact same problem (although it happens even
while the sustain pedal is not depressed) - Driving me nuts.
I cannot rectify.
using OS 10.4.10 / PT 7.3.1 with 002 rack - controlled by M_Audio
Keystation Pro 88.
anyone know how to deal with this?
Old 11-07-2007, 09:49 AM
DigiTechSupt's Avatar
We are aware of the problem and are working on a fix for it.
Avid Audio Tech Support
Support FAQ
Old 12-25-2007, 07:55 AM
relse relse is offline
Please see my post "How I solved my midi double note problem" in the MIDI forum - might be the same or similar issue.
Old 12-25-2007, 05:20 PM
accession accession is offline
And here's the link:
http://duc.digidesign.com/showflat.p...c=1&PHPSESSID=
Though it seems this 'sustain' issue is different. Great that Digi's already on to it too.
Old 10-03-2008, 02:11 PM
erecords erecords is offline
I cannot rectify.
Keystation Pro 88.
I just started having this same problem myself. Has there been a solution posted?
The link in the thread does not work.
Midi notes lagging/hanging/sustaining PyneBoxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-08-2012 07:42 PM
Help w/Midi Notes Infintitely Sustaining JustinTapp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-10-2010 02:26 PM
Notes sustaining with PT 7.4cs7 joey44 MIDI 3 07-25-2009 12:51 PM
Structure free - Notes not sustaining anymore Murt Virtual Instruments 4 05-12-2009 03:30 AM
Double Notes!!!! roziel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-02-2007 09:30 PM
