Opening PT 6.1.2 sessions on OS 9 in PT 5.2.1
For the past year I have been taking my laptop around with me and using it with PT 6.1.2 and my MBOX and getting some great sounding recordings. I have also been using it as my main recording source, but truthfully I just like the way the PT 5.2.1 work and feels a little better. Pluss I have so many people that I have been working with that use the OS 9 version. Anyway... I just recently got my G4 back (Long story) Previously it had 001 on it but I sold that and just bought an MBOX to mix with. Well everytime I try to play a session that i recorded on 6.1.2 in 5.2.1 it gives me this "DAE error 9060". I tried all the fixes that the answerbase gives and that didn't help. I also tried re-formatting the hard drive and that didn't help. I then tried to see if it would work if I just started a new session from scratch and that worked. So this leads me to beleive that I am having trouble reading the newer version files in the OS 9 version of Pro Tools. Sorry for the long-winded explaination but I figured a little history would help. If anyone can help me figure this out I would greatly appreciate it!! Thanks!
Matt |
Re: Opening PT 6.1.2 sessions on OS 9 in PT 5.2.1
go to your 6.x session, save session copy in,
in session format choose 5.0, in fader gain +6db, items to copy all suondfiles, etc. burn to disk that saved copy, or copies, take them to the OS9 5.x system, hope it helps.
so what |
You shouldn't have to do any of that, PT6 sessions should have no problem opening and running in 5.2.1 - I do it pretty often between my home setup with 6.4 and my TDM studio running 5.1.3. Post back and let us know if re-saving the session solves the problem, it shouldn't, but it'd be good to know if it does.
Well I tried that, but it didn't seem to work. I still get DAE error - 9060. I am out of things to try. Any other ideas?
Thanks Again! |
Your session document is not the problem the format is the same for versions 5.1 or better. . If you have tried all the solutions in answerbase it could be that the audio is corrupt. Try using import tracks to bring the tracks into a new empty session one at a time to see if you can determine if it is a particular track. If these sessions still opens on your OS 9 rig try using save session copy in with items to copy all audio files selected. Try changing the audio file type so that new audio files in a new format are created. Most of the time this error is caused in OS 9 by having the drive formatted improperly with an unsupported 3rd party utility or having 3rd party firewire extensions like HDST, or Silverlining Pro loading. Hope this helps, Thanks, Digidesign Tech Support |
Well, I tried both of those suggestions and when I imported each individual audio file over I was able t hear audio. But that seems like it will be easier to re-record than to peice together all those files. I also tried moving the files to the system HD and that didn't change anything. Niether did converting to .wav. Any more suggestions?
thanks! |
hi shade, if you import each individual audio file at a time,
it´s best to consolidate each track from the begining, so you don´t have to deal with where it goes. what digi mean, was that when you imported each audio at a time, there´ll be one or some that could not be imported ´cause it´ll be a corrupted file, so when you identified it, you´ll delete it, ´cause it could be the cause you are unable to open the whole session in 5.x
so what |
hi slim, but what if it's only one region of a track that's corrupted?
ones happens to me that i reversed, put delay and don't know what else to a region, and when trying to consolidate it told me it cuoldn't be done 'cause there was a corrupted part. thanks.
so what |
Unfortunately once you find the track that has the corrupted region or file, you need to remove that corresponding file and delete it. I don't believe there is any way to un-corrupt something (short of some kind of religious ceremony, and computers and holy water don't mix to well).
Opening old sessions in 7.4 | PTPerson | Pro Tools TDM Systems (Mac) | 5 | 03-09-2009 11:03 PM |
Opening TDM Sessions in LE... | Sparky1 | Pro Tools TDM Systems (Mac) | 4 | 03-26-2006 03:25 PM |
Opening sessions | Keybeeetsss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-26-2006 10:05 PM |
Opening HD sessions in d24 | Nomad | Pro Tools TDM Systems (Mac) | 0 | 10-09-2002 07:34 PM |
Opening old Mix sessions in HD? | generator | Pro Tools TDM Systems (Mac) | 5 | 01-31-2002 10:47 AM |
