How to get the kick and snare velocity even?
hello dear fellows!
I trigg my drums with DFH Superior. They sound super but some snarehits really hit you as a shotgun in the soundpicture. I played it for reall but need to get the snare velocity quite ecual somehow to get the snare even in volume. Lets say all 2 and 4 between 124-127 to get it even or something like that. Is the any way to do it without taking dead of my live feel and groove? Thanks in advance! |
Re: How to get the kick and snare velocity even?
MIDI > change velocity ...
Yogev Samina |
Ok velocity ... but I dont wanna spend one day to edit every snare hit.
I know there is some kind of "set every note between 120-127" or something like that. Like a midi compressor. |
Highlight the Midi Drum Track then use the duplicate selected tracks under the file heading. Use select notes under MIDI heading and selct and delete ranges above and below Snare note. Then high light the track again and change the word that says 'notes' to 'velocitiy' under the track name in EDIT mode. then either adjust manually or select change velocity in MIDI heading and use setting to adjust as desired. Don't forget to select and delete the snare note from the original drum track once you are happy with your edit... Hope that helps, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
man that helped!
Thank!!!! |
seperate snare and kick | cuzinfunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-08-2007 01:52 AM |
Another test from the DOC - X73i on Kick and Snare | IntelDoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-22-2005 04:09 PM |
That Big Ol Kick and Snare!!! | Opal Music | General Discussion | 5 | 01-23-2003 04:20 AM |
help seperating kick dr and snare help | ALAN MCKNIGHT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-27-2001 03:06 PM |
Triggering Kick and Snare in PT Using midi | makerthemaker | Pro Tools TDM Systems (Mac) | 4 | 10-25-2000 10:26 AM |
