#4091
Re: Best Desktops for PTLE
Hi, I'm looking to upgrade the CPU of my rig, currently a 2400+ XP on an A7N8X-D. What's the best 32-bit socket A CPU out there? The Nvidia chipset hasn't given me troubles with PT LE that I know of so far...
#4092
Allen |
#4093
Allen |
#4094
Hello all. After reading everything from 6/04 to present, I have a few questions...
I just purchased an Mbox along with a K8V-X, 3000+ (I know, I know, 3700+) and Win XP Home. This machine will be audio only. I have built at least 10 computers, I love to overclock and tweek windows (this machine will be tame and stable though). I already have 2 Hitachi 80 GB SATA drives along with an Antec 350 watt power supply, LiteOn CDRW/DVDrom and 2 x 256 MB Kingmax single sided ram modules. I also have a nice Antec case with a 92mm rear fan, the stock A64 HSF and a fan controller. My question is regarding the K8V-X's single sided ram requirement that is stated in the manual (there was a post regarding this last year). To retain DDR400, 2 or 3, single sided sided sticks can be used together or 1 single + 1 double sided stick together. Basically, I think I can only install 3 "sides" of ram and still run at DDR400. (manual, page 1-11 http://www.asus.com/pub/ASUS/mb/sock...1879_k8v-x.pdf ) Since I have not been able to find single sided, 512 MB sticks I will have to use only 768 MB of ram, which I can live with (not a power user, yet). Which DDR400 configuration would be most stable?: I use my 2 x 256 (single sided) and buy one more 256 MB stick, totaling 3 sticks and 768 MB or I use one of my 256 sticks and buy a 512 stick (double sided), totaling 2 sticks and 768 MB? Do I even need to worry about single and double sided? I would rather get 2 x 512, but there are no single sided 512 MB sticks. I think I have been in "matched pair, dual channel" mode for too long and the thought of using 3 sticks or different size sticks is scaring me. Thanks for any help and a big thanks to Allen for the great thread. |
#4095
Yep!
I have some memory questions too: The K8V mobo have 3 sockets for 184-pin DDR Ram, and I already got 2x 512MB DDR400, I have check the mobo manual, and there says that to use the 3 DIMM, the max speed for all 3 sockets is DDR200! This means that I can get another DDR400 module and will only work at DDR200 speed, or to use the 3 sockets, I need to get DDR200 instead? Thanks
[G5 1.8Mhz][OS 10.3.5][DP 4.12][Cubase SX2][Ableton Live4][Reason 2.5] [AMD64 3200+ 2000Mhz/1MB L2][XP-Pro] [ProtoolsLE 6.1][Cubase SX2][Reason 3] |
#4096
I'm currently considering upgrading to the Allenstein machine, but with a few tweaks recommended by the computer guy at the store (in order to save some $$$). I was wondering if these changes were alright or would cause some problems.
1. Change the 80 Gig HD's to a lower capacity, say 40 Gig. 2. Change the Athlon 64 3700+ to a 3400+ 3. Change the ATI Radeon 9600 to a MSI Radeon 9550SE 128MB TVO 4. I don't think I'll need a DVD drive, so I'd go with a CD burner. I don't know much about this, as it may show. I just don't want to guess at buying a setup and have it give me sub-optimal results again. I'll be running an m-box with PTLE. Any recommendations on this setup or how I may save a little more $$$ without compromising performance? |
#4097
According to the manual's chart, the max amount of ram you can use and still preserve DDR400/FSB200 is 768 MB, either with 3, 256 MB single sided sticks or with 1 256 (single sided) and 1 512 MB, (double sided). You cannot run 2 512 MB sticks and retain DDR400/FSB200, assuming all 512 sticks are double sided. Again, this is all according to the manual. (edit: or you can use a 1 GB stick) This brings me to my question, above. Which is more stable? 3 x 256 or 1 x 256 and 1 x 512. If this situation is true, then I hope this helps anyone trying to decide which K8V motherboard to use. Personally, I didn't want all the extra features of the "deluxe" version, but if I had know about the ram limitations of the "X" version, I might have bought one anyways. This thread is great, but it doesn't really mention the K8V-X's limitations as far as memory configuration. |
#4098
Go to www.crucial.com to get the correct ram for the K8V-X motherboard. Allen |
#4099
Allen |
#4100
Hi again, I forgot to say, that my mobo is not the K8V-X! Its the K8V SE Deluxe. So, can you tell me if I use 3 DIMMS of DDR400 the system will speed down the sockets to DDR200?
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
