Old 12-14-2021, 06:09 AM
diogomusique diogomusique is offline
Default Plugin not working properly in DSP mode
Hi guys.
When I arm rec my track automatically goes to DSP mode. But when I insert any plugin it doesn't work properly. I have to disable DSP and re-enable to have the plugin working.
Is this meant to be like this?
thanks
Old 12-14-2021, 08:53 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Plugin not working properly in DSP mode
Originally Posted by diogomusique View Post
Hi guys.
thanks
Hello,
Can you explain what you mean by not working properly? Which plugins are affected? Which version of Pro Tools?
Native-only plugins will be automatically bypassed for tracks in DSP Mode as DSP Mode require DSP plugins for processing. However, it doesn't sound like you're running into this if disabling/enabling the plugin resolves the problem.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 12-14-2021, 09:10 AM
Hi, Kyle!
I think I found the problem (not the solution )
I tried some other DSP plugins and all of them worked properly, I could hear the effects when changing its controls.
When I open one of my Default EQ or Dyn they doesn't work. I had to disable the DSP icon and re-enable it have them working.
As I said before this just happens with Default EQ and Dyn, any other DSP plugin (I use Avid and Plugin Alliance) works well.
I'm using the latest version of Pro Tools Ultimate 2021.12.
Old 12-14-2021, 09:12 AM
Hi, Kyle!
Ok, thanks for the info. What are your Default EQ and DYN plugins? Which version of macOS are you using?
Kyle Splittgerber
Berkeley, CA
Old 12-14-2021, 11:33 AM
They were (I removed them from default and they're working well): Avid Channel Strip and Purple Audio MC77. I'm using Catalina 10.15.7
my computer: Mac Pro late 2013
Old 12-14-2021, 11:35 AM
Thanks. Can you successfully instantiate Avid Channel Strip and Purple Audio MC77 when they are not the default EQ and DYN plugins?
Kyle Splittgerber
Berkeley, CA
Old 12-14-2021, 11:42 AM
Yes!
Old 12-14-2021, 12:03 PM
Yes!
Ahhh! Ok, sounds like a bug in the instantiation code when coming from Default EQ/Dyn. We'll look into it.
Kyle Splittgerber
Berkeley, CA
Old 12-16-2021, 10:24 AM
K Roche's Avatar
K Roche K Roche is offline
Just a note, I have the PT EQ III and the PT Fairchild 660 (mono) set up as my defaults and they work fine ???????? What I have noticed is I can't set the Fairchild 670 (stereo ) as the default, the 660 is the only one showing in dropdown for Dynamics ???
System :
Enjoy the Journey
.... Kev...
plugin flip mode on artist not working Cryos Avid S1, S3, Dock and Control App 7 10-26-2021 05:58 PM
Spot mode not functioning properly JonBJoyce macOS 2 01-23-2021 04:01 AM
plugin selection shortcut still not working properly 100% of the time!!! thebeatless Pro Tools 12 2 07-07-2015 04:43 PM
Learn Mode in EQ3 plugin not working j20056 macOS 5 10-14-2014 06:57 PM
002 not working properly in standalone mode. nosebleed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-26-2003 06:30 AM
