Old 02-20-2016, 08:18 PM
GoGoJoe GoGoJoe is offline
Default Opening multiple sessions at the same time
Is it possible?
PC Dell XPS 8700, i7 CPU @ 3.40GHz, 4 Core(s), 8 Logical Processor(s). 32 GB RAM, Windows 8.1
Recording Pro-Tools 12.4. Mbox Pro 3 (Driver 1.1.10) FireWire CPU Interface w/ Presonus FADERPORT.
Old 02-20-2016, 08:27 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: Opening multiple sessions at the same time
Not possible. What's your reasoning for wanting to do that?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 02-21-2016, 10:32 PM
The_Skywalker The_Skywalker is offline
It's possible you just need multiple computers
Old 02-21-2016, 10:55 PM
jchan jchan is offline
Other daws has the ability to copy paste parts, regions/clips between multiple open sessions and its great for some peoples workflow. Import sessions data or export clip groups is not nearly as neat.
Old 02-22-2016, 05:20 AM
Drew Mazurek's Avatar
It's a long requested feature.
But I think so long as HDX is around (fixed DSP and voices) you won't see it because there's simply no way to have two sessions trying to use the same DSP and I/O etc.
I suppose it's possible for Avid to make it a non DSP only feature but considering currently PT is all the same code, I wouldn't hold my breath.
www.drewmazurek.com
Old 04-11-2016, 08:55 PM
Ok cool, thanks for the info
Sent from my SM-N910V using Tapatalk
Old 04-12-2016, 04:04 AM
7Seas's Avatar
7Seas 7Seas is offline
With 12.5 and Cloud Collaboration it seems to be indispensable...
At least there should be the possibility of opening various Projects with the same session at the same time. If you are collaborating with more than one person we should be able to have different projects, based on the same session, working simultaneously.
Old 04-12-2016, 04:40 AM
As long as both sessions aren't playing at the same time the dsp usage wouldn't conflict. Digital Performer can't strictly have two projects (their term for our sessions) open at the same time but you can have multiple sequences open at the same time. Their sequences are a lot like our sessions in that each can have their own MIDI tracks, audio tracks and instrument tracks (DP uses the old school approach of separate tracks for MIDI and vi hosting; their instrument tracks only host a vi).
Old 04-12-2016, 04:49 AM
Great to hear!! I had no idea it was so easy. But then I'm not a programmer or have intimate knowledge about how HDX is coded etc.
www.drewmazurek.com
Old 04-12-2016, 05:22 AM
KV626's Avatar
KV626 KV626 is offline
Yeah but that's still one document open (project, session, whatever it's called). DP's unique chunks feature is indeed the closest we get to having multiple projects open at the same time, but it's still one document, and there's no way to cut/copy/paste either to the next open one. On a side note, DP's behemoth UI can be a real drag, to say it politely, with large sequences. Anyway, that's a debate for motunation not the duc
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Breaking up multiple songs in one session into multiple sessions? rmandelbaum Windows 10 08-14-2013 10:05 PM
opening multiple plug ins with pt 10 pinnacle macOS 7 10-26-2011 08:20 AM
Opening old PT sessions in PT8 ducada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-29-2009 03:11 AM
Opening multiple plugins at the same time lululu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-19-2007 10:22 AM
Opening PT 6.1.2 sessions on OS 9 in PT 5.2.1 shade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-17-2005 08:31 PM
