Old 11-27-2010, 12:20 AM
dbazan dbazan is offline
Default main menu bar missing. pls help.
hello there.
i'm new to pc/windows 7(used macs for ten years) so i've been having a little trouble but nothing major until...
i accidentally closed the "main window" in pt9 and the mix and edit windows along the main menu bar disappeared with it. now i can't get any of them back open to save my life.
i've tried using the window configurations in the demo song. looked in the manual for any shortcuts. i even reinstalled pro tools. still nothing. when i open pt the transport is there, plugin windows, i can load almost any window except the mix/ edit/ and "main" windows.
any help would be much appreciated.
thx
Old 11-27-2010, 03:48 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
Can u post a screen shot? The mix & edit windows are the main windows so I'm not sure what u mean as I guess the others who peeped in don't get it either : confused:
Sent from Epic 4G Using Tapatalk on'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-27-2010, 04:45 AM
Meads Meads is offline
Default Re: main menu bar missing. pls help.
Yeppers.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-27-2010, 10:46 AM
The Weed's Avatar
The Weed The Weed is offline
Did you look under Windows in the main menu bar?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-28-2010, 01:10 PM
http://i1090.photobucket.com/albums/...an/photo-1.jpg
here's a link to a photo of the screen.
pro tools is running here. you can see the counter and transport. i can navigate to different points in the track by dragging the counter numbers up and down. i can play/stop the track with the transport. (i can't move the faders, so i can only monitor the "current" mix).
but as you can see there is no menu bar.
i can bring up all kinds of different windows using keyboard shortcuts but not the mix or edit windows. and also not what i was calling the "main" window which i guess is just whatever "window" that contains the main menu bar.
thanks for the responses i've gotten so far.
perplexed,
dave
Old 11-28-2010, 01:16 PM
Dism Dism is offline
Do you just have the one screen?
Have you tried the shortcuts or menu options to bring up the edit/mix windows? (ctrl+=)
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 11-28-2010, 01:18 PM
Default
Wow'zers!!! That's a new 1.. & even on a reinstall it stays that way?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
[IMG] code is Off
Main Window missing!!! Please help! BigHE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-16-2010 05:34 AM
12dB missing on main bus TDM Mix+ w/ PT 6.4.1 rantanplan Digidesign Hardware & Software 1 12-22-2009 11:00 AM
Altiverb 6.2 XL missing from TDM insert menu Nitefly Pro Tools TDM Systems (Mac) 2 09-28-2008 05:27 PM
Help menu and NI missing tlennon Tips & Tricks 1 06-19-2007 12:44 PM
Missing"Other" Button in Hardware Menu/5.0 David Horner Pro Tools TDM Systems (Mac) 0 04-09-2000 11:54 AM
