  #181
Old 11-11-2016, 04:05 AM
Drew Mazurek's Avatar
Default Re: Fine breakpoint adjustment change in 12.6 = Showstopper
If this is a deal breaker continue to use 12.5.2 until 12.6.1 comes out as Kyle stated earlier in the thread.
www.drewmazurek.com
  #182
Old 11-18-2016, 04:26 PM
Normann Büttner Normann Büttner is offline
Having found this thread now I'm finally sure that there's no need to prolong that subscription plan.
I'll stay on PT 10 forever (Even if I already own a 12 License - it's because of that awful AVE)
One of the main reason for ProTools users not switching to other DAWs like many here in German and Austrian Filmpost have done already is that we DONT want to change our habits. When AVID starts changing their own trusted features then even that reason not to switch is gone!
MacPro 5.1, 12GB, OS 10.8.5 HDnativePCIe, stepped back to Pro Tools HD 10, Machine Control, Euphonix Control V2
www.meloton.de
  #183
Old 11-30-2016, 12:49 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hi All,
Thanks for your feedback regarding the breakpoint changes in 12.6 and patience while we worked on fixes. We have just released 12.6.1 with the following breakpoint editing improvements/fixes:
• Grid Toggle is disabled when adjusting automation, MIDI, or Clip Gain breakpoint controls in Slip Mode to avoid conflict with fine-control editing (PT-221294)
• Pressing the Command key (Mac) or Control key (Windows) while editing automation and MIDI breakpoints now suppresses Grid mode and enables fine-control editing. This is now consistent with breakpoint editing behavior for Clip Gain. Fine-control editing can be disengaged during mouse-down by releasing the Command key (Mac) or Control key (Windows), and then re-engaged by pressing the Command key (Mac) or Control key (Windows) again (PT-221952)
• Using the Smart Tool to add a breakpoint on a Clip Gain line no longer incorrectly constrains the breakpoint to the nearest grid line (PT-221919)
• Fixed multiple automation breakpoint editing inconsistencies with Grabber Tool (PT-221862)
12.6.1 Release Notes here.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #184
Old 11-30-2016, 01:09 PM
bolooki bolooki is offline
Default Fine breakpoint adjustment change in 12.6 = Showstopper
Originally Posted by Kyle Splittgerber View Post
Hi All,
Great news! Thanks for letting us know.
Does this update also address the slip/grid/"clutch" edit behavior introduced in 12.6 as far as editing and trimming waveforms is concerned? (Ie not just breakpoint editing). Didn't see that in the release notes.
Thanks!
  #185
Old 11-30-2016, 01:20 PM
Thanks!
No. Grid Toggle for clip editing has not been changed. For instance, you can still switch between Grid and Slip modes while trimming clips via Command (Mac) or Control (Win) keys.
Kyle Splittgerber
Berkeley, CA
  #186
Old 11-30-2016, 02:00 PM
TOM@METRO's Avatar
Thanks Kyle. Great stuff in this release.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #187
Old 11-30-2016, 02:18 PM
Is this something that would be addressed in the future?
Or is there any 3rd party way around it? That new behavior really interferes with my editing speed. I had rolled back to 12.5.2 just because of this.
Thanks!
  #188
Old 11-30-2016, 02:31 PM
Thanks!
How is it interfering exactly? If you don't want to enable Grid when in Slip while trimming clips, just don't hold Command (Control) key.
Kyle Splittgerber
Berkeley, CA
  #189
Old 11-30-2016, 02:42 PM
Might sound silly but- I swap from slip to grid quickly, so I am just used hitting cmd a lot when I edit regardless of what mode it's currently in. So I keep accidentally hitting it while in slip and the cursor suddenly is not where I want it any more. Basically my brain and hand are used to "holding cmd=fine adjustment" all the time. The new feature is now making me have to constantly check which edit mode I am in before making the edit. This is no bueno!
I feel like this is close to the same issue people had w fine breakpoint adjust issue that was fixed. It's something small that can be worked around but the extra thought now involved to edit as I always have is really distracting.
Hope that helps! Thanks for the reply.
  #190
Old 11-30-2016, 02:47 PM
The Weed's Avatar
The Weed The Weed is offline
Kyle, thanks for this and for posting here. Could you please have a look at this thread?
I posted this as you mentioned it in your post #139.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Fine Fader Adjustment On iPad? producedbyriot Avid S1, S3, Dock and Control App 4 09-10-2016 01:00 PM
Fine Adjustment on AAX seems to be Broken? Neil Pickles AAX Plug-ins 4 06-07-2013 01:39 PM
fine adjustment of breakpoints not working levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-03-2010 06:42 AM
Fine volume adjustment gbours Pro Tools TDM Systems (Mac) 3 05-02-2006 07:23 PM
Strip Silence and Fine Adjustment... Still a bug? SimpleNatureSpirit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2004 11:22 PM
