Old 11-20-2001, 01:49 PM
stickstome2 stickstome2 is offline
Default PC TO PC SESSION MOVE.
OK, I saved a session folder from a friends pc ptle and tried to bring the session up on my pc to add drums to, everything starts to work fine then it says I need to move it to a valid audio drive first, the window pops up with the folder and audio but when I double click on the folder to open it up I get that same message----couls somebody please give me step by step procedure to get this to work---tech support on the fon is 40 minutes behind.
thanks
stix
Old 11-20-2001, 01:55 PM
electrobank electrobank is offline
Default Re: PC TO PC SESSION MOVE.
This will occur if you are trying to run the session off the CD. You can't.
You must first copy the session onto your hard drive, then run it.
electrobank
2+2=5
Old 11-20-2001, 02:20 PM
Mark_Knecht Mark_Knecht is offline
Try this. Works for me and my PTLE friends:
1) Open Windows Explorer, and go to your CD.
2) Select all the files you want to copy.
3) Right click and say copy
4) Go to the session directory where you normally keep audio for your session.
5) Right click and say paste
6) Select all fo the files again, right click, go to properties and uncheck the 'write only' button.
At this point you should be able to at least open the session. If the location you place files in isn't named the same as your friends, then you may need to tell Pro Tools where the audio data is, but after that, you shouldn't have any trouble.
Mark
PT9 Saves a Session Copy in my Mac HD after I move a Session BJosephs macOS 4 04-06-2011 01:26 AM
How do I move a section from one session into another session? spur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-21-2008 09:21 AM
move session from Nuendo to PT TDM ?? Nad4 Pro Tools TDM Systems (Mac) 1 12-08-2007 08:13 PM
move session from Nuendo to PT TDM ?? Nad4 Post - Surround - Video 1 12-08-2007 08:59 AM
How to move HD session to 001? Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-12-2002 05:36 AM
