Old 06-22-2014, 05:56 AM
jasperhb jasperhb is offline
Default AAE ERROR -30001 - with PSP VintageWarmer 2 and other PSP plugins
Anyone else having issues with using PSP Audioware AAX plugins in PT 11.1.3 on x64 Windows 8.1 (update 1)(*)?
I can use PSP Audioware plugins if I start a blank session and use no other plugins, but if I use for instance VintageWarmer2 on a more complex session with multiple tracks, busses and other plugins I will get an AAE ERROR -30001 and for every new PSP Audioware plugin I add the AAE ERROR will occure with an increment fo the error code - i.e. -30002, -30003 ... -3000n.
I've seen the error with VintageWarmer2, OldTimer, RetroQ, ClassicQ, BussPressor and more, but I've not seen it with PPM2.
Any ideas what this is and how to run Diagnostics? I've raised a support question with PSP Audioware and are awaiting their response.
Rgds
(* The PC was reinstalled from the buttom up this very week. I had the issue on the previous installation also.)
Rgds
https://soundcloud.com/1iveowl/
Pro Tools 2018.4, Windows 10 Pro x64 (w/ latest update), i9-7980XE, ASUS TUF X299 Mark II, 64 GB Memory, Samsung 850 2TB SSD, UAD Apollo Twin II TB, RME Fireface USB, UAD-2 Octo PCI, Plugins: UAD Waves, Softube, FabFilter, Lexicon, NI Komplete 11 Ult, Celemony, Slate Digital, PSP, Arturia V Collection 6, FXPansion, iZotope, SoundToys, Spectrasonics...
Old 06-22-2014, 07:15 AM
WKG WKG is offline
Default Re: AAE ERROR -30001 - with PSP VintageWarmer 2 and other PSP plugins
They seem stable for the most part but I did experience a rare crash when toggling the Fat setting on Vintage Warmer2 yesterday. I haven't seen the errors you mention though.
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6
RME, Daking, Heritage, ISA, Sytek
Old 06-23-2014, 01:02 AM
Update: Just got word from PSP Audioware that they are working on an update that is likely to address the issue.
Rgds
Old 06-23-2014, 07:19 AM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
These PSP/AAX errors have existed for many months, no? We had to go back to RTAS for some of their plugins.
Old 06-23-2014, 09:49 AM
Yes, I've seen the error for a couple of months. It seems PSP is aware of the issue and that they are currently working on an update to the plugins.
Rgds
Old 07-18-2014, 03:16 PM
Still not fixed but I know they are trying.
Have anyone else seen this error and been able to zero in on the cause?
Thanks
Rgds
Old 07-18-2014, 03:34 PM
WKG WKG is offline
There is a beta on the VW download page. I haven't tried it but maybe it's a fix in progress?
Old 07-18-2014, 06:06 PM
Last week I went to PSP's site and downloaded all plugins again, even though the version numbers hadn't changed. After installing, all plugins which I own (and it's most of PSP's) are displayed correctly. I don't know if PSP made changes or if it's related to ProTools updates but I don't care - they're working!
Old 07-19-2014, 02:20 AM
I've gone further than that. I reinstalled the whole PC.
The tricky part is that if I start a new PT session I have no issues adding psp plugins to it, however if I try to add psp plugins to an already buzy session then I see the error.
Also, if I add a psp plugin early in a session it will continue to work even as the session grows, however it will not work if I start adding psp's late. It is really a tricky bug this one.
Btw, all other plugs I own that are axx 64-bit compatible on a PC works fine. And I own quite a few plugins gathered over the years.
Rgds
Old 07-19-2014, 09:07 AM
Yes, that is odd behavior from a plugin.
AAE -30001 Error with VTM Dot Pro Tools 11 5 03-18-2015 01:37 PM
AAE ERROR 30001 - with Slate VBC FG GRAY Seafoam_Green Pro Tools 11 7 05-13-2014 05:53 PM
Air plugins DAE ERROR 7054 MEAT Pro Tools TDM Systems (Win) 7 12-27-2008 07:43 PM
PSP VintageWarmer & MasterQ vrs Ozone.. vieris Pro Tools TDM Systems (Mac) 2 06-23-2005 06:10 AM
DAE -7401 w/PSP VintageWarmer ... whtrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2004 11:00 PM
