Transferring Mix to DVD/promotional mix
I have recently finished a mix that was made for a promotional DVD. Everyone in the band signed off on the mix, and now 2 weeks later, they are complaining that it doesn't sound good through a television(i.e. that video company that put my mix with the DVD sent them a copy after they had put the mix with the DVD). I am not sure what type of conversion needs to happen when adding a mix to video, and I am really not sure what to do to make the mix a little more "4 inch mono speaker:<) compatible. Any suggestions?
HD3/Accel with 192 i/o Dual Mac G4/1.25ghz, 1 Gig Ram OSX 10.3.9 Control 24 |
Re: Transferring Mix to DVD/promotional mix
did you mix it on nice, decent montors? and they approved the mix in your room? or did you check on auratones, some other crappy speaker, car, boom box etc. if you didn't check the mix on a TV type speaker, then you would only be guessing at what it might sound like.... i mix differently for TV.
you may need to explain to them the difference between a studio monitor with a tweeter and a 10" bass driver and a 4" single driver speaker.... you also need to ask the company that made the DVD if they made an AC3 file, or compressed the audio to an MPEG stream. if they did (which they had to in some form) you may want to ask them what settings they used. some default DVD programs make the audio sound like a bad mp3. if they knew what they were doing, then your audio should be pretty good and you are back where you started at the beginning of my post. hope this helps
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Anybody have a promotional code to buy the crossgrade LE to Pro Tools 9 | Hayesland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-03-2010 07:33 PM |
Promotional Code | abre | Pro Tools M-Powered (Win) | 0 | 12-07-2006 09:00 AM |
Transferring WIN to MAC | jpd52 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 06-20-2002 12:07 AM |
HD3 promotional plugin pack? | bp78 | Pro Tools TDM Systems (Mac) | 1 | 04-23-2002 09:52 PM |
Do I Get The HD Promotional Plugin Pack | chris67 | Pro Tools TDM Systems (Mac) | 1 | 04-07-2002 08:28 AM |
