Old 07-16-2019, 02:51 AM
bad jitter bad jitter is offline
Default Maximum width of Edit Window?
I wonder if the width of Edit Window is somehow limited to 5120 pixels? I am using three 2560*1080 displays, but cannot stretch Edit Window to fill all three of them, but only about two.
Old 07-24-2019, 12:36 PM
Default Re: Maximum width of Edit Window?
Am I the only one with this first world problem?
Old 07-24-2019, 12:38 PM
I would test for you but my display is limited to 3840 pixels wide. From your data I would suspect the window width is restricted to two display span, not any actual pixel amount
Old 07-24-2019, 12:43 PM
I think it's pure pixel maximum. I can position Edit Window to fill half of the first display, the second entirely and half of the third one. But thanks anyway!
Old 07-24-2019, 12:44 PM
If so, contact Avid Support and raise your concern. There should not be such a restriction and if there is, fixing it should be easy for the next release. I mean, what I am supposed to do with the thousand MIDI tracks if I cannot see them on my displays?
Old 07-24-2019, 12:47 PM
Oh sorry, that pun went wrong. I was thinking about mix window -- that's where width really counts
Old 07-24-2019, 12:51 PM
You are in trouble then. The maximum width of the Mix Window is even less; about 3840 pixels.
Old 07-24-2019, 12:56 PM
Not yet. That happens to be my max width currently
Old 07-24-2019, 12:58 PM
Raised this question for mod team. You could still do yourself (and all the others) a favor by contacting Avid Support and let them officially know you have a problem.
Old 07-24-2019, 01:32 PM
Ok thanks. How should I contact the support?
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
How to adjust Track Width in Edit Window larsongs Getting Started 14 06-16-2014 09:14 PM
Mix Window Channel Width? Katrien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-21-2008 07:24 PM
changing width of markers window fred54368 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2001 12:46 AM
