Old 12-04-2022, 05:49 PM
littlesicily littlesicily is offline
Default Normalize Audio Suite malfunctioning
I believe this has been an issues from 2202.06 to current .10.
Basically I'm using the Normalize Audio Suite plug to select a bunch of takes of the same vocal phrase, and normalize all of them the same peak or rms. Using “clip by clip” is supposed to analyize each file individually + "create individual files” + “use in playlist”. It used to work in some previous versions. Was a really fast way to clip gain files.
Anyone else having this issue or am I missing something obvious?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1
Old 12-05-2022, 02:16 AM
mr xy mr xy is offline
Default Re: Normalize Audio Suite malfunctioning
yes - I've run into this myself on several occasions
Old 12-05-2022, 09:21 AM
Ok, good to know it's not just my system.
Old 12-07-2022, 06:58 AM
Your needs may be different than mine, but I almost never use Normalize. For music mixes(what I do), the last thing I need is hotter tracks. If a track was recorded too low, I use Clip Gain to bring it up to fit the rest of the audio
Old 12-07-2022, 07:07 AM
daeron80 daeron80 is offline
At first, I read the title as an imperative. It's OK that Audio Suite malfunctions. It's normal!
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 12-07-2022, 11:00 AM
Actually, I'm not normalizing to "0"... rather, the normalize plug can be used to set ANY peak or RMS level. For ex. let's say you prefer all guitars have a -18RMS level... use the Normalize plug to do it for you rather than hand adjusting each or having to calculate the difference needed to set the GAIN plugin.
The problem is that the Normalize Audio Suite plug is malfunctioning from what it's supposed to do. Argg.
Old 12-08-2022, 11:11 PM
jeffro's Avatar
jeffro jeffro is offline
Curious if these are 'whole file' clips or not? Might help to get a session or at least repro steps and a screenshot of all the Normalize settings. Is there a support case yet?
linkedin
Old 12-09-2022, 11:01 AM
nednednerb's Avatar
nednednerb nednednerb is offline
To answer the initial question, normalize clip by clip creating individual files works OKAY for me in 2022.10.
The other part of the question, when I happened to test the operation, the middle clip was clip gained down, so the peak didn't seem to match the other normalized clip peak visually. Is that "obvious" thing eluding you? When I cleared those clip gains, the peaks displayed the same level.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 12-15-2022, 08:01 AM
These are not whole clips. What I'm attempting to do is select several takes of a vocal phrase and normalize them all to the same peak level... in this case -12db. See attached screen shots of the takes and my settings. I'm wondering if maybe I have some setting wrong or if there's a glitch happening.
Old 12-15-2022, 08:02 AM
I didn't have any clip gain +/- in this scenario but thanks for asking. Always worth double checking.
I/O is malfunctioning GCWilliams Pro Tools 2018 1 05-31-2021 07:45 AM
Having real problems with NORMALIZE (audio suite) twirk Pro Tools 10 0 11-03-2013 12:33 PM
Normalize audio when master to cd? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-07-2011 07:51 AM
Audio suite effects on an audio track question Majorek Tips & Tricks 7 02-08-2007 08:25 AM
Normalize several audio clips swpowe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-13-2005 01:39 PM
