Old 12-03-2022, 09:36 AM
psycho's Avatar
psycho psycho is offline
Default Pro Tools 2022.10: Melodyne Edits Missing After Relinking Clips
In a session, all Melodyne (ARA2) edits were lost! Was some hours of work and client was present. He was not amused.
"Expert Plus Support" was unable to help ("Trash preferences" blah blah, you heard it before ).
So I investigated myself and found that it was caused by moving audio data to a different drive (and relinking again).
Steps to reproduce:
1. Do some Melodyne edits
2. Save and close session
3. Move audio clips to a different drive
4. Open session and relink missing audio clips
5. All melodyne edits are lost! "Melodyne notes" are still visible as clip overlay! A new analysis will run automatically (eventually).
"Some Melodyne track data can't be found. Melodyne edits on affected tracks may not playback correctly." might be reported if you are lucky but in most cases nothing is reported.
Watch here: https://youtu.be/4OQv-egClxA
To even further verify relinking success, I also did some clip effects and, as expected, those were still present after relinking.
If you move the audio files back to their original location, everything will be fine, unless you did a save session in the meantime.
I am using Windows. Maybe some Mac user can verify if this happens under Mac OS too.
PT Ultimate 2022.12, HD-Native PCIe, 4x 192 I/O, Sync HD, MIDI IO, 2x Pre, 40 Channel Icon D-Command, X-Mon
PC: Windows 10 Pro, Intel i7-10700KF, 32 GB DDR4 3200 RAM, MSI MEG Z490 Ace, Nvidia GTX 950
Notebook: Windows 11 Pro, i7-1165G7, 16 GB RAM, 2 TB SSD
Old 12-04-2022, 06:56 AM
midnightrambler midnightrambler is offline
Default Re: Pro Tools 2022.10: Melodyne Edits Missing After Relinking Clips
Can confirm I’ve had the same issue.
Old 12-04-2022, 09:02 AM
This makes a good argument for committing early, especially if you plan on moving or copying the session to another drive(although I don't know why you had to relink).
Old 12-04-2022, 10:02 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Yes Dave. I've experienced this issue, so I do my ARA edits in little chunks and commit as soon as I'm done, one small clip at a time.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 12-04-2022, 12:15 PM
psycho's Avatar
The point is that when moving sessions from desktop to notebook (where the file-paths start with a different drive-letter (Windows), thus (auto-) relinking required), committing doesn't help. I would not be able to continue Melodyne editing on the notebook as un-committing with different file-paths reveals the bug.
Old 12-04-2022, 12:46 PM
Tweakhead Tweakhead is offline
wow. that's outrageous. and having to commit is not a solution.
what if there's some minor adjustments you need to make with fresh ears the next day ? C'mon Avid - get it together.
In the meantime, can we have an option to hide ALL these now utterly useless TABS eating up all that space at the bottom of the Edit Window ? and/or a preference to move them to the top near the timeline.
Old 12-05-2022, 03:09 AM
You see now I think I would argue the opposite - it's better to work from one consolidated file, rather than a number of different files on the same track. This is certainly the case for Elastic and it would appear that I'm also getting fewer errors this way using ARA. (I appreciate this is not exactly a rigorous scientific test though :))
Old 12-12-2022, 02:29 PM
[email protected] sleshnyc@gmail.com is offline
this happened to me and i didn't move anything. this is freaking outrageous. I've lost hours of work. it's utterly unacceptable that avid hasn't sent out a warning telling people about this.
Old 12-12-2022, 02:48 PM
fwiw I went to an autosaved version and found one prior to the session being corrupted. I save the last ten versions every 5 minutes.
fwiw, I also save as each day with the date, so that the worst case scenario is I only lose today's work.
Old 12-12-2022, 03:10 PM
psycho's Avatar
Update:
I opened a new support case after my investigation.
Once again i was told to trash (Melodyne) preferences, which of course had absolutely no effect.
Finally today someone from global support in Poland answered. He said:
I am suspecting a known bug here. Just need to run some tests to verify if your workflow matches the issue we are already aware of and it shall be fixed with the upcoming Pro Tools release.
I will contact you after I am done with testing.
I will keep you updated.
Some Melodyne track data can't be found. Melodyne edits on affected tracks may not pl JingleDjango Pro Tools 27 02-07-2023 06:48 PM
Melodyne doesn't render properly after TCE Tool 2022.10 and 2022.9 Dizzi45Z Pro Tools 4 01-04-2023 02:31 PM
Pro tools (2022.10) crashes often with the use of melodyne (at least per clip). cmbourget Pro Tools 5 12-18-2022 01:35 PM
Melodyne Quantize Time Macro in Pro Tools 2022.9 ARA 2 not working properly c_carmody314 Pro Tools 1 10-23-2022 12:36 AM
Pro Tools Studio 2022.05 is not showing video in the clips list Kewbass Windows 3 06-23-2022 10:35 AM
