Old 12-02-2017, 10:21 PM
teedeecee teedeecee is offline
Default iLok Flipper - Plugin Stress Reliever
Hi Folks,
Here is a small simple app that may have some use for some people.
My main studio business runs on an installed Mac Pro, but often I will be at a gig elsewhere and have to use one of my MacBook Pro's for work. Often, I will need to boot an app such as FCP, Ableton or Reaper for some small edit or large multitrack record that doesn't require any third party plugin.
The issue is that I need to connect my iLok Dongle otherwise I will be faced with dozens of individual dialogue boxes alerting me to the fact I have no authorisation. Usually this is impossible (as the dongles are connected to a Pro Tools rig) or inconvenient (I have already used up my USB ports on the machine with Audio Interfaces).
So I have made a small app that renames the AU and VST plug folders so as to prevent these apps seeing them. The result is the apps do not load the plugs, and the apps boot must faster. Running the app again toggles this renaming then opens the plugs directory at the conclusion to indicate the current state.
The app will require you to authenticate as these directories are not in your home path. You can check what the app is doing by "Show Package Contents". In there you will see a tiny apple script that loads a Bash Shell script that just checks for the current folder name and renames accordingly.
You can download the iLok Flipper.app here.
Note: Remember to put the folders back to their default state before installing any new plugs, otherwise you will need to spend some time combining the folders.
Enjoy, and let me know if you have any issues.
Cheers,
Tony David Cray
Old 01-06-2018, 12:34 PM
cariprez cariprez is offline
Default Re: iLok Flipper - Plugin Stress Reliever
This is great. It always gets pretty frustrating when i'm trying to refresh or open something on my laptop and I get notified that I don't have authorization for my Slate and Soundtoys plugins because I don't have my iLok with me. Going to check this out. Thanks for the post!
Old 01-06-2018, 04:03 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Dang I need that for my windows machines
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Slate fg-stress released WombatStudio.Org AAX Plug-ins 25 09-30-2017 12:20 PM
Plugin auth weirdness - guest iLok prevents internal iLok? Scott Helmke VENUE Live Sound Systems 3 09-07-2011 07:06 AM
PT9 stress test? sneakyimp Windows 24 07-17-2011 02:17 AM
A PT stress test? Inthewoods 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-27-2010 06:32 AM
PCI stress, why? the_riot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-20-2001 11:18 AM
