Old 01-06-2002, 01:16 PM
MrMike MrMike is offline
Default MIDI drum track
I use a BOss drum machine. I recorded a drum track with the MIDI interface using the feature where recording is started only when the play button is pushed in the transport window. The drums both sound like and look like they are in sync with the beat timer in PT. HOwever, when I examine the MIDI track visually, ie. looking at the measures/beats in the edit it looks like the drum 'beats' are a little ahead of the beats in the measures. I hope this makes sense.
I'm new to MIDI btw.
Mr. Mike
we all must answer to the invisible whip - Rasaan Roland Kirk
Old 01-06-2002, 01:32 PM
Roy Howell Roy Howell is offline
Default Re: MIDI drum track
Hi Mike(excuse me, MR. Mike [img]images/icons/wink.gif[/img] ),
First, make sure your 'Low latency Monitoring' is checked under 'Operations'. But really, if you're not HEARing a discrepancy, I wouldn't worry too much.
Post back though with any questions anytime, Midi or otherwise, and one of us will help you...
Roy
rh music
Old 01-07-2002, 06:17 AM
mlemos mlemos is offline
MrMike,
It sounds like you weren't using 'input quantize'. Just select your midi track and then use the quantize feature in the midi menu.
Marc
How do I add drum sound to a midi track? RunningFree Pro Tools SE and Essential (Win) 2 05-10-2011 11:41 PM
MIDI Drum Track Not Playing bmcoonan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-18-2009 03:23 PM
i need to slow down the end of a midi drum track billymc MIDI 3 05-24-2006 04:05 AM
Utility for splitting midi drum track DonaldR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-19-2002 06:06 AM
Controlling a drum machine with a MIDI track j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-27-2002 12:31 AM
