Old 09-27-2010, 01:35 PM
The Oxygen Kiosk The Oxygen Kiosk is offline
Default Issues with 003R
I've had my Digi 003r for a couple years now, and its worked fine the entire time. Then, I sit down to do some tracking, and Pro Tools will only load as far as "DAE loaded" and then it goes into "Not Responding". In addition, the rack does its normal relay clicking, but then the entire front panel lights up and none of buttons are responsive.
Pro Tools will register when I don't have the Digi connected, but will still not load with it plugged in. I have tried a firmware reset, but because the MIDI light stays lit up (along with the rest of the panel) I can't be sure if its reacting to it.
Any thoughts?
Windows XP SP3
Pentium Dual-Core CPU
E5200 @2.50GHz
2.49 Ghz, 3.25 GB RAM
Maxtor 1TB Hard Drive (2)
Pro Tools LE 7.3
Digi 003R
Old 09-27-2010, 01:55 PM
JMS40 JMS40 is offline
Default Re: Issues with 003R
Have you upgraded to Internet Explorer 8 recently?
Old 09-27-2010, 02:00 PM
Nope
Old 09-27-2010, 09:36 PM
leester1172 leester1172 is offline
Good Luck look @ all my posts last version for XP, go back to 801 or 803. Sorry everyone wasn't going to post but this is B.S. AVID FIX YOUR PROBLEMS AND STOP YOUR MARKETING BU!![bleep][bleep][bleep][bleep][bleep]
FIX IT!
Old 09-27-2010, 09:37 PM
Sorry Mis-read your post, might be a hardware problem, trash preferences, re-loaded firmware??? Unplug all USB devices, and launch. Can you define what day it happened? Possibly a system restore may help if you can
Old 09-28-2010, 01:46 PM
I have deleted all PT Preferences and Digidesign Databases. I tried a system restore to a date when it was working fine and nothing changed. I would reload the firmware, however (if you read my first post) none of the panel buttons are responsive.
003r w/ Presonus D8 - SYNC issues YYR123 Pro Tools 9 5 12-09-2011 04:37 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 08:19 PM
HP i7 Laptop - W7/64 - PT8.0.3 - 003r = Issues OmniDigital 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-02-2010 07:26 PM
Firmware Issues With OSX/XP 003R Eway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-08-2009 11:55 AM
Serious issues with 003R macdeath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2007 07:46 AM
