Re: Pro Tools Motherboard compatibility...New computer being built
As with all other of lifes big issues, you are not guaranteed anything, regardless of what you do, but at least the PC builders has more stores to return to. |
I can confirm the following for three Pro Tools versions (LE8, 9, 10) -works with G-Skill Ripjaws RAM overclocked to 1600 -works with hyperthreading on (4x2 cores) -works with hyperthreading off (4 cores) -works with overclock (at least with my 960 upped to 3.8 GHz) A few things: 1) I turn AERO off, and set the shortcut for pro tools to "disable desktop composition" 2) PT runs better for me when utilizing 3 of 4 cores (hyperthreading off) 3) I am currently using MBOX 3. Milage may vary for other interfaces I suppose. 4) I have tested two firewire interfaces, both had dropouts and driver problems with the motherboard's built-in FW port. I installed a 3rd party PCI express card with the TI chipset ($25 from NewEgg) and that fixed it. 5) while PT works even with this processor overclocked to 3.8GHz, I reduced it to 3.4 because of heat concerns. Currently using the Antec Kuhler 620 closed-loop liquid cooling system |
I recommend the system below or a variation of it.
I also recommend the latest version of Studio One 2.0 Pro for quick relief when PT10 starts PMSing. CPU - AMD FX-8150 3.6GHz Memory - Corsair Vengeance 16 GB DDR3 1866 MHz ( PC3-15000 ) Motherboard - Asus Crosshair V Formula Motherboard Case - Antec Solo II PC Case Power Supply - Antec HCG-900 FireWire - FireWire 800 3-Port PCIe NN-E38012-S3 Blu-ray Drive - Sony Optiarc BD-5300S Blu-ray Disc Writer Video - XFX Radeon HD 6970 - Graphic Card Hard Drive - 2 Hard Drives 2 x WD Caviar Black 2 TB CPU Cooler - Thermalright Venomous X - RT 120mm CPU Cooler |
#16
http://www.newegg.com/Product/Produc...82E16814125386 |
#17
Avid claims to have no comparability with most AMD CPUs and current FX series especially don't work. What's worse is, they will never fix the problem. Reaper.fm ^I'm going back to it, you should look into it. |
#18
This matter is a nightmare to enter into.
#19
My nightmare consisted of choosing a popular motherboard with a history of working, putting in a case, loading PT10, and being able to create music.
I hope I recover from the horror of it all without a massive psychiatry bill. |
#20
And how bad was the processor selection and video card issues? So far I have been thinking Asus P8P67, but now I see other suggestions. Some guy tried this motherboard in another thread - its socket 1155 and he tried with 1155 and had issues. Others are on 1366 socket, some have issues some dont. Therefore I dont know what to do. There is no 100% percent confirmation on what the most ideal possible system will be. See, I told you this was a nightmare. (I am not going AMD). |
Need Computer Built | ejwells | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 30 | 02-05-2012 06:13 PM |
Need DDR3 Motherboard Built in Firewire Whom Have Had Success With | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-23-2010 08:40 AM |
PC Motherboard compatibility with Pro Tools M-Powered 8 | redyetistudio | Pro Tools M-Powered (Win) | 1 | 10-25-2009 04:17 AM |
Pro Tools Free Computer Compatibility | mp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-26-2001 11:25 PM |
Pro Tools Free Computer Compatibility | mp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-25-2001 07:52 AM |
