Other Samples with Structure?
I was watching the Structure video on the Digidesign website and Phil Jackson mentioned that he was using samples from Native Instruments in Structure.
Do all Native Instruments work in Structure? Will they work in the "Structure Free" version? What about samples from other companies like.... Sonic Reality Refill Samples East West Samples... From "Colossus" etc, Thanks. |
Re: Other Samples with Structure?
I believe that you can do that with Structure LE. Structure Free is limited to the preset patches only, IIRC.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
right on. my bad.
you can import them, but you cant map them.
Many of the EastWest collections (like Colussus, SD2, etc) are in the proprietary "Play" format as a VI and can't be imported into any other sampler. I think Digi has a couple of EastWest libs that have been formated specifically for Structure though. There are lots of sample libraries that are in the Kontakt or EXS24 format that can be imported.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Thank You Guy's!
Could you please explain what it means to..... "Map the Samples" |
you cant reassign the keys that play the sample.
Samples for Structure | mmcl | Virtual Instruments | 3 | 06-05-2013 08:07 PM |
Foley/FX Samples for Structure | [email protected] | Post - Surround - Video | 10 | 03-18-2009 02:19 PM |
Looping samples in Structure LE. | Blank Frank | Virtual Instruments | 1 | 02-26-2009 12:39 AM |
Structure samples don't sustain | TOM@METRO | Virtual Instruments | 6 | 12-28-2008 04:19 PM |
Help Loading samples in Structure | 14choirs | Virtual Instruments | 2 | 07-19-2007 05:31 AM |
