Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-14-2009, 02:26 PM
sleazedc sleazedc is offline
Default Select Waves 6.1.1 Plugins Folder
Alright. I'm running MP-8 on OSX 10.5.5 / PowerPC
I haven't been having any problems until earlier this week. I removed some Waves Plug-ins that I had on trial. Now when I launch, I get a pop up asking me to locate waves 6.1.1 plugins folder. However it is a frozen window that does not allow me to navigate within it. So PT just hangs and I have to force quit at some point. I've left it running for hours this week to see if it would pop up and let me select a folder, but no dice.
I have reinstalled Waves, and I have reinstalled PT8 but I still get the same error. ;-/
I have a lot of work to do and would appreciate any help if anyone has come across this before. I am running the B&P Waves Bundle (fully licensed of course).
Old 11-14-2009, 02:32 PM
Default Re: Select Waves 6.1.1 Plugins Folder
I have not upgraded to Waves 7 just FYI
Old 11-14-2009, 03:21 PM
Avid's Avatar
Avid Avid is offline
Administrator
See if this helps...
www.digidesign.com/plugingrid
Waves Issue In Pro Tools 8
When launching Pro Tools, the Waves dialog "Where is the Waves Plug-Ins folder?" may pop up behind the Pro Tools splash screen and may become inactive after bringing it to the foreground.
To solve this issue:
1. Right click on Waves Plug-ins folder and make Alias
2. Rename created "Alias to Waves Plugins" (capitalization is very important) to : Waves Plugins
3. Copy alias (to clipboard)
4. Go to ~/Users/Current User/Library/Preferences/
5. Create new folder and name it Waves Preferences
6. Paste Waves Plugins alias(from clipboard) into created folder (Waves Preferences)
7. Delete alias that you created in step 2
8. Start Pro Tools
Administrator
Old 11-14-2009, 07:42 PM
There is already a folder under my user/current user/library named Waves Preferences and it already has an alias folder named "Waves Plugins"
I followed the steps you listed for the most part- I created/copied/pasted the new alias to the existing Waves Preferences Folder- then deleted the existing one already present, then went back and deleted the alias I had just created from step two. So only the newly created alias folder was in the already existing Waves Preferences folder.
No luck.
Should I delete the existing Waves Preferences folder and all of its contents and then create a new empty one, and put the new alias folder in that?
Thanks for your help!
-Simon
Old 11-14-2009, 08:01 PM
user/current user/library/preferences/Waves Preferences... My file path is correct ;-)
Old 07-05-2012, 09:10 PM
Karizz4KrayzeApesMediaLan Karizz4KrayzeApesMediaLan is offline
just wanted to say thanks! Not often you can find instructions that lead you down a path clear and concise. It worked!
ItsKarizz2u,
Krayz'e Apes MediaLand Productions
Select Waves 7.1 Plug-Ins Folder DR_LI Pro Tools M-Powered (Mac) 2 10-06-2012 01:12 AM
select Waves 6.06 plugins folder in 8.0.1 a7bull 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-17-2009 10:47 PM
Waves plugins folder issue yop22 Pro Tools TDM Systems (Mac) 0 09-01-2009 08:43 AM
Waves 6.0.6 won't let me find plugins folder abbyin3d Pro Tools TDM Systems (Mac) 9 05-20-2009 08:32 AM
Waves 6.0.6 and Pro Tools LE 8 - "Select Waves Plug-ins Folder" - Windows XP toustab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 03-14-2009 01:13 PM
