Re: Missing plugins in AudioSuite / system freeze
So I don't have a fix, but might have a little clue? |
My rig is okay otherwise and I have enough plugins as Audio Suite to cover my bases although I wouldn't mind having NI in there. |
Whoa there, solved my Waves problem via thread here - http://duc.avid.com/showthread.php?t=327997 . I had to hold down shift on launching PT, and after a while a secret mystery dialog appears for Waves plugs. There was a checkbox ticked for "don't use audiosuite plugins". Who knew THAT was there?! And a few stock ones have showed up too, like Vari Fi, on the PT 10.3.9 install, so getting there. Unviel is still AWOL which used to be there on the old rig, but I think that's it at the moment.
EDIT - yes, looks like some plugs won't show up by design, but I think everything in my case has been some other issue like the Waves one here. EDIT 2 - Win some and lose some. Unviel now appeared after an AAX reinstall, but Waves appears to forget its setup state, and reverts to "don't use in AudioSuite" every time. Off to start a new thread in the aax section.... |
OK, so I'm now good to go with all my plugs in AudioSuite. Thanks to all who helped - as sometimes happens, looks like it was a combination of factors.
Not yet sure if I've licked the system freeze. Has only crashed with PT open. Since the last freeze I've clean uninstalled 10.3.8 (well, supposedly clean) and reinstalled PT 10.3.9 and updated the BIOS chipset. So far so good, but its an intermittent fault of course. If it does it again, I'll be moving / ditching the powered USB 2 hub that hosts the iLok as the next test. |
All plugins missing including audiosuite in pro tools 10.3.7 | sinawavak | macOS | 2 | 12-02-2013 03:02 PM |
All plugins and audiosuite missing in Protools 10.3.7 (Win7) | TheBaron | Pro Tools 10 | 5 | 09-08-2013 05:11 PM |
Anyone else have Audiosuite plugins missing after installing PT 10? | kilroyrock | Pro Tools 10 | 5 | 05-07-2012 01:24 PM |
rebuilt my system and missing a few plugins | SNAPPER | Windows | 1 | 01-19-2012 05:27 AM |
Audiosuite Plugins Missing | skermajo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-20-2004 10:17 PM |
