Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
#21
Ok, first thing - Go through the Optimization Guide. Then try my other suggestions from one of my last posts: Do you have USB 2 ports you could connect the Mbox to, or a USB 2 hub to put between your laptop and Mbox? Also, be sure you've installed the latest drivers for your USB controller.
Joel
Jame Space: HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro Pro Tools 12 HD / M-Audio Project Mix IO Rig: Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM |
#22
I have installed all of the latest drivers and tried running the MBOX in every conceivable USB side port and external multi-USB port. It just wants to blow up my machine.
**JAY TERRIEN** BASS ~ VIOLA ~ ARRANGEMENTS With Artists STEVIE WONDER, MOBY, RIHANNA, ESPERANZA SPALDING, RANCID, JOSH GROBAN, ALIEN ANT FARM, ANDY GRAMMER, THE BODEANS, FRANK OCEAN, PAT MASTELOTTO (KING CRIMSON, XTC, THE SUGARCUBES) etc. E-mail: jay@jayterrien.com http://www.reverbnation.com/JAYTERRIEN http://www.facebook.com/JAYTERRIEN http://www.twitter.com/JAYTERRIEN http://www.myspace.com/JAYTERRIEN http://www.jayterrien.com/home.htm |
#23
According to the picture you posted, I would suspect some kind of IRQ conflict. If it were me, I would reformat the hard drive and reinstall the OS and drivers via the factory reinstallation disk.
James Cadwallader Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6. Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac) Pro Tools 11.3.2, Mbox2 (Win 7) Presonus Faderport, Pro Tools | Control |
#24
I don't want to do that exhaustive/devastating of a restore unless absolutely necessary.
I can get the MBOX to play and run audio through it, but only for a few minutes. Then it gets glitchy, fragmented, it stops, starts again, and then BSOD. What else can be done to solve the IRQ issue?
#25
There is a IRQ conflict listed under the device manager. Intel chipset, Intel management engine interface, and NVIDIA GeForce GTX670M are all listed under IRQ # 16.
Does this mean anything?
#26
Even after doing a billion tweaks and set-ups, this MBOX is still having some kind of a massive problem. It runs for about a minute, and then audio gets garbled, and then BSOD. I cannot believe that all of the device reinstalls that I have done have not easily solved this problem. It is all about the AVIDMBOX.sys failing. Help!
#27
Have you tried a basic USB 2 hub between the Mbox and PC?
Joel
#28
At this point I'd call it a day on trying to troubleshoot, do an image back up of your current drive and just reinstall Windows 7. Or, pop a new drive in there and do a fresh install on the new drive.
These days I can't make it past trying to troubleshoot something like this for more than a couple days before I just bite the bullet and do a fresh install. It sucks if you have lots of software to reinstall but it's better than pulling your hair out for three weeks. |
#29
I tried the USB to PC and it still gave me a BSOD.
However, I tried a different interface, a Focusrite Scarlett 2i2, and it has worked flawlessly. How is this possible?
Mbox 2 Not Recognized (only when plugged in after...) | deathpoet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-02-2011 10:18 AM |
PT9 won't start without mbox plugged in. | stubied | Pro Tools 9 | 8 | 02-27-2011 03:22 PM |
Mbox 2 driver re-install randomly whenever MBox plugged in | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2008 09:22 AM |
MBox plugged in 24/7? | SeasonOfPain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-06-2004 11:47 PM |
Mac MBox plugged into a PC | MGalway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 08-25-2002 01:07 AM |
