Mix Split Question with 192 i/o
I need the main final mix, stereo mix outputs to go to BOTH the analog outputs AND the AES outputs on my 192 i/o interface. So far I can't seem to do it? I know how to assign multiple outputs on audio tracks, but not on the master fader?!?
------- xxx |
Re: Mix Split Question with 192 i/o
I've never had to do that but... Maybe add a second master fader assigned to the other outputs?
Sorry, that was unclear.
Can I route my signal to 2 places on my interface after the master stereo fader?!?
------- xxx |
------- xxx |
Yeah, I guess I would duplicate my master fader track and assign the duplicate to the other outputs.
Slang,
No, assigning another master fader doesn't work. Seems the only mess around is to use an aux stereo input as your master fader, then use a send to another output on the box. However, this is extremely messy. Digi, can't we just configure the i.o setup to double up some outputs? It's a lame way to mix... you put the multimple outputs on the individual tracks.. why not the master fader?!? Sorry for the dbl post... I planned that to go along with the question I'm asking about double outputs.
------- xxx |
I found the answer in my handy Digidesign 192 i/o manual. You can do it. You just have to go back to default and start over with i/o.
------- xxx |
Great! How?
very weird way to do it... seems like a kludge solution but it works great.
Go to page 20 of manual... Basically, when you revert to "default settings" in your hardware setup, it automatically mults analog output 1 & 2 and the enclosures AES outputs. You're screwed if you want >96k and 2 outputs at once. It says you can also "route" them using the control key but I couldn't make that work and am now officially tired of dealing with it... I got my solution and I'm moving on to trying to understand my wife's pms... a worthy challenge.
------- xxx |
Have you tried command-control-clicking the output of the master fader to an AES output of the digital I/O card? That's the way you used to do it in a Mix system. Hope this helps, MasterJ |
MIDI question: How to use note split. | toecat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-24-2012 12:59 PM |
Split to mono question | blackbirdstudio | Pro Tools TDM Systems (Mac) | 5 | 01-18-2011 12:15 AM |
D-Control 32 split or no split? | Don Geppert | ICON & C|24 | 8 | 01-30-2007 10:15 AM |
[ot] fcp question: can you split screen . . . | love666 | Post - Surround - Video | 2 | 12-22-2004 02:51 PM |
002 split disk | Bar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-22-2002 02:35 AM |
