Waveforms not displaying proper gain when bussing?
Hello. I don't know if this has been covered somewhere else, but my search revealed nothing, and searching the duc is pretty difficult to find anything relating.
I'm autotuning and bussing to another track. fader is at zero. i record to the new track, and voila! the waveform looks as though it is about 6 db lower. i copy the region back to the original track, everything looks good. it's just a pain in the ass when trying to line up to the sample level. any helpers? pt Le 7.1 cs4 (i think) |
Re: Waveforms not displaying proper gain when bussing?
check your vertical zoom settings.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
How are you sending to the second track? Make sure you're either using a mono bus output from the original or pan hard left (or right) to the bus you're using as the input on the second.
not sure where the vertical zoom settings are, or how they would affect how one track looks, and not the other.
i am using a mono buss. the track is not actually down in volume, it just looks down, until i pull it up to the track i'm bouncing from. i was just wondering if anybody else has seen this problem. jd |
Actually, I've seen this problem ever since the PT 7 upgrade (currently running 7.1cs6) Never really thought about it much since I could usually care less what the waveform looks like, but it's definitely happening just the way you describe it.
I've run across it while Autotuning as well; I'll set the output of my vocal track to, say, bus 32, and create a 'tuned' audio track with input 32. Stick Autotune on the vocal track, tweak a phrase, then record it to the tuned track. When you look at the waveforms side by side on the vocal and the tuned track, the tuned version appears several dB down. And yes, I've made sure my vocal track volume is set to 0, and there's no other plugins active on that track. The meters read correctly at the same volume. Thankfully, when I move the newly tuned region back to a new playlist on the other track, it magically appears at the right volume. Strange! |
good, i'm not the only one. i also noticed yesterday that when i copied a region from one track, and pasted it onto a track below that the same thing happened. i don't get it.
any ideas digi? |
Calibrate monitors...for proper gain staging | Loudyman | Pro Tools TDM Systems (Mac) | 7 | 04-14-2012 05:19 PM |
Waveforms Not Displaying Accurately. Anybody? | alex@action | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-19-2009 05:22 PM |
Gain, level on preamp vs gain on Digi (guidelines)? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-04-2007 08:18 PM |
Proper Gain Staging - where to attenuate? | kid pro | Pro Tools TDM Systems (Mac) | 8 | 02-14-2003 06:04 AM |
preamp and proper gain settings | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 12-28-2001 01:27 PM |
