Old 11-11-2001, 07:43 AM
sandman sandman is offline
Default where is the matrix ?
when i'm on grid mode i normally have the matrix quentized lines between each bar /time/sample ...right
so did i press some key that checkd that ?
i still can move a region based on the quentized selection but still no matrix ... [img]images/icons/frown.gif[/img]
thanx for any reply
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow!
Old 11-11-2001, 01:41 PM
mfym mfym is offline
Default Re: where is the matrix ?
You need to set the main window to Bar:Beats and set a grid value from the grid window.
Also, use Identify Beat to change tempo.
Hope this helps. [img]images/icons/smile.gif[/img]
Old 11-11-2001, 01:45 PM
very strange couse i dont have any vertical grid lines !!(m not sure its the right word ) . but even when you'r on slip/shuffle mode you have a grid which is connected to the main time mode (bars,beats/mins secs/
but on a session i'm working on right now
there is no grid what so ever ... [img]images/icons/confused.gif[/img]
still i can move regions though the selected quantize steps BUT i cant see them ,,,, [img]images/icons/frown.gif[/img]
also !!
when i stratch the work space(apple+ { } )
it takes too many Msecs to do it ,every time i "ask" the system to do that it looks like a freeze activity is comming ...
any idea ?
G4. 450mhz . 256 ram
PT 5.1
digi 001 .
20g system
30g audio trash can
cheers [img]images/icons/cool.gif[/img]
Old 11-11-2001, 05:47 PM
CCash CCash is offline
Sounds like the problem is what Obsessed is describing. In the top left above the track I/O in the Edit window, you'll see the timeline types -- Bars/Beats, Min/Sec, etc. There is a little radio button beside them. Click on this button.
Old 11-11-2001, 06:46 PM
yes ! thanx ppl , found that button [img]images/icons/shocked.gif[/img]
Old 11-12-2001, 12:17 AM
Sugarite Sugarite is offline
Unfortunately nobody can be told what the Matrix™ is... [img]images/icons/cool.gif[/img]
(had to be expecting that one...)
So you're looking for a visual grid on the edit window? Not sure if that's possible, but probably an option somewhere.
(quantizing is lame anyways [img]images/icons/tongue.gif[/img])
Old 11-12-2001, 12:39 AM
OBSESSED OBSESSED is offline
There is a button in the upper left of the edit window just above the your top track. Put it in grid mode and start hitting them all. I don't have access to a pt screen right now otherwise i'd give more specifics.
peace
V
Cue on Mains to Matrix J2sound VENUE Live Sound Systems 3 04-17-2012 11:47 AM
Matrix Mixer lscroggin VENUE Live Sound Systems 1 04-12-2009 05:49 PM
MATRIX ROUTING Shai VENUE Live Sound Systems 2 01-23-2006 10:13 AM
Restore the Matrix! Mano ProControl, Control|24, Command|8 13 10-27-2004 03:35 PM
M-S matrix tirt1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-01-2002 08:30 AM
