Old 06-18-2002, 10:50 AM
khansen khansen is offline
Default click tr records w/ audio...help.
G4/466, PTools, Digi 001. - I want to record an audio track using my Korg N1 synth along with a click track without recording the click track too. I've routed the click track via midi to channel 10 of the Korg, but it still records on the audio track. I must be missing something major. Help? Thank you from a new user.
Old 06-18-2002, 11:24 AM
DigiTechSupt's Avatar
Default Re: click tr records w/ audio...help.
<font size="2" face="Verdana, Arial">-Unless your synth has multiple pairs of audio outputs, the audio from your MIDI click with be routed out of the same outputs as your desired patch. If your synth is only equipped with a single (stereo) pair of audio outputs, then you will have to do one of the following:
1-Record the click from your synth to an Audio Track in your session.
2-Use QuickTime Musical Instruments (or another synth module) to provide your click.
Brent
Avid Audio Tech Support
Support FAQ
Why are Audio & Midi Records always Latched? One Track Music Pro Tools TDM Systems (Mac) 14 09-03-2020 08:30 AM
Beat records earlier than click track mojobadshah Pro Tools 9 0 06-29-2013 05:30 PM
Pro Tools Records Audio in the Wrong Location! xx1messxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-28-2007 07:05 PM
Audio records early while using MBox2 Pro CS10987 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-23-2007 09:13 AM
Needs a quick fix... audio records a split second too early mrlenderful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-02-2007 09:32 AM
