ADC not working w/ HDX summing two inputs
When I record el.guitar, I've been trying to use 2 mics into 2 aux inputs, then summing the 2 auxes to a mono bus to a mono record channel.
PT reports "0" samples of latency / ADC but after the re4cording is done, the summed audio file is late...sometimes! It's so unpredictable and frustrating. Is this a known bug or am I missing something?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1 |
Re: ADC not working w/ HDX summing two inputs
why don't you just record on two mono channels with both panned center?
same result sound wise and no routing delays.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Yes, but when I have 6 egtr passes, that's 12 tracks...six groups to keep the blend and six more busses to process them. Just too messy. I have been bouncing each pair to disk after recording them discretely but was hoping to avoid this extra step bc ADC is SUPPOSED TO WORK!
This may be a known bug. Check the Pro Tools Read Me:
Automatic Delay Compensation cannot not be applied to tracks recording from different types of sources (PTSW-157960) Automatic Delay Compensation cannot compensate for cascaded records that use both I/O and bus inputs to recording tracks. An example of this is feeding an audio track (in record) from an audio input, and then bussing the output of the track to another audio track also in record. The first audio track will be compensated but the second cascaded track will not be. (This is not a common workflow.) This looks a bit like your workflow. |
two live aux inputs > mono buss > mono record track.
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1 Last edited by littlesicily; 11-12-2019 at 10:02 AM. Reason: correction |
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
You're right. I read his response too fast.
My situation is two live aux inputs > mono buss > mono record track.
Well, I said 'This looks a bit like your workflow.'
The point being that as soon as you get an intermediate aux or bus in between, PT can no longer properly manage ADC. This pops up in a lot of alternative workflows, believe me, and I hope is a feature they will properly implement very soon. ADC currently only works properly in all but the simplest scenarios. Don't go side-chaining or bussing arround.. |
Correct. But In his scenario it’s supposed to work. Sent from my iPhone using Tapatalk
Supposed to yes, but doesn’t He has to change his workflow to get anything done, yes it’s a drag but the other options are don’t get anything done and or get another daw. That description of the readme sounded like basically anything Deeper than just main track recording is problematic I would trash prefs and try again. If that didn’t work I would downgrade to the last know version that was working and Park it there I am running 12.5.2 for this same reason, I just need the stuff to work - I don’t need the latest bug infected release
Inputs not working | Weenerdude | Pro Tools 2018 | 1 | 12-26-2018 11:28 PM |
Mic Inputs 1-3 not working since PT8 | cqd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-09-2009 08:14 AM |
Mic Inputs Not Working. | ghost104 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-15-2007 07:04 AM |
pro tools summing or digital board summing | kingz | Pro Tools TDM Systems (Mac) | 9 | 04-29-2004 12:46 AM |
Summing two mic inputs to one track. | losttimestudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-28-2004 12:16 PM |
