just installed 11.2.2 on nMP - uninstall before updating to 11.3?
Last night I began the process of fresh installing PT11.2.2, Air Creative Collection and all 3rd party plugins on my new MacPro (2013). PT11.2.2 is working fine (based on very quick check) and I'm less than halfway through the process of downloading, installing and authorizing 3rd party plugins.
Now I see that 11.3 has been released - what timing! At this point I plan to just keep going, finish reinstalling all plugins, verify that everything's working and then update to PT11.3. Possibly stupid question: I shouldn't need to un-install PT11.2.2, correct? The download and install of PT11.3 will simply overwrite/update the PT software and everything else - Air Collection and plugins - should be unaffected, right?
Current system: MacPro (Late 2013) 3.5 GHz 6 Core, 32 GB RAM OSX 10.12.5 Pro Tools 12.8 Apogee Duet 2 Glyph Drives + Blackmagic dock with Samsung SSDs Reason 10, Ivory II, BFD3, Finale Plugins: Kush, Kontakt, Komplete Ultimate, Exponential Audio, Waves, Slate, Fab Filter, TDR, Pultec Bundle, Bomb Factory, UVI Workstation, Sonnox, Soundtoys, Massey, Valhalla, Aether, PhoenixVerb, etc... also 17" MacBook Pro w Core i7, OSX 10.9.4 |
Re: just installed 11.2.2 on nMP - uninstall before updating to 11.3?
There is no uninstaller for PT11, it's not needed.
Just run the new 11.3 installer, and it'll know what to do. |
The 11.3 installer isn't a drag and drop like the last few. It is labeled as a Full Installer. I uninstalled 11.1.3 from the new installer then installed 11.3. Also if you are running HD install the drivers after installing ProTools because the driver installer requires a restart but ProTools does not. Just a bit of a time saver.
I do believe Drag and Drop installers for PT11 will return. This one was done this way to get it out the door more quickly and to lessen issues with OSX gatekeeper.
Regards, JC |
JC, with that Video Engine issue in mind, would you recommend simply deleting the PT11.2.2 app from the Applications folder before installing 11.3? Or running an uninstaller (which I'm assuming is an option in the 11.3 install folder, based on CygnusX's post).
Uninstall help | bootus | General Discussion | 0 | 05-03-2014 04:22 AM |
now that PT10 is installed, should I uninstall 8 LE? | Rotundra | Pro Tools 10 | 3 | 12-08-2012 07:08 PM |
How do I uninstall PT10? No 'Uninstall' option in Control Panel | epu | Windows | 5 | 06-26-2012 06:25 AM |
Updating PACE drivers... before updating to 9.0.5 | lanstrad | Pro Tools 9 | 0 | 08-28-2011 07:37 PM |
Updating HD7.2 to HD7.4. Will plugins need updating? | Ru_C | Pro Tools TDM Systems (Mac) | 4 | 08-14-2009 04:02 AM |
