  #21
Old 09-22-2017, 10:36 AM
Inglesworth Inglesworth is offline
Default Re: no audio
Your screenshots are a little small. however, I think i see an issue on the one you posted that shows the "Outputs" tab of your io setup window.
The outputs on the tracks behind the io setup window are going to a bus that is obviously not named the same thing as the main output (1-2) of your saffire pro.
All the tracks seem to be routed to an output that starts with the letter "M..." but you do not have an output by that name in the io setup window.
  #22
Old 11-18-2020, 04:31 AM
annahumphries's Avatar
annahumphries annahumphries is offline
Hi, I installed all the wave plugins, had no problem. Now none of them is showing up in pro tools I'm lost...Help.
Assignment writers in UK
  #23
Old 11-18-2020, 05:07 AM
Ben Jenssen's Avatar
Hi. Welcome to the forum.
You should really create a separate thread for your help request. Or perhaps a forum moderator can do it for you and find an apropriate section to put it in.
Meanwhile, we need as much info as possible about your system. And you should check all standard optimizations and troubleshooting recommended here:
Help Us Help You
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 09:28 PM
Audio Suite process puts new audio in audio bin Fritz12534 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-21-2009 08:55 AM
PRO TOOLS giving 2 Audio track ''Audio 5_02.L and Audio 5_02.R'' fredson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-20-2008 09:08 AM
How can I bounce mutliple audio/instrument tracks as mono Audio files in ProTools LE thaprof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-16-2008 11:03 AM
USB2 Audio HD vs Fw Audio HD vs internal audio HD seth666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-07-2005 02:06 AM
