Old 04-02-2009, 10:38 PM
Logic Pro Logic Pro is offline
Default Installing PT with no digi core audio driver
hi
I run Logic and Pro Tools MP ion the same machine, and i want to upgrade to a PT LE to get the dv tool kit etc add ons.
I have been advised to install PT with no digi core audio driver, what will i be missing in PT if i do so?
Old 04-06-2009, 08:12 AM
Default Re: Installing PT with no digi core audio driver
Originally Posted by Logic Pro View Post
hi
bump
Old 04-06-2009, 08:27 AM
telemerase telemerase is offline
no PT functionality will be changed. if you have a usb audio interface its not going to make a difference either way. if you have a firewire interface you will not be able to route core audio sounds to your digi interface. itunes/other audio apps, web browsers, games, etc..
Old 04-07-2009, 01:41 AM
well i guess the only solution is to share the HD system at the studio, then export wav files to logic, since digi's portable Pro Tools systems can not provide the same functionalists, maybe they can think of something like to print effects to tracks that can not work on LE as well as every other non post function, either wise Prosonus Studio One just about does everything Pro Tools does now, accurate and way cheaper.
best of luck with digi guys, i cant use this stuff with no PDC, no use opening a PT session if the TDMS wont work or resolution is lower, so i get rid of this pro tools HD Demo (which is what it really is) i am out of here., thanks for the post anyway.
BYE BYE
Digi Core Audio Driver nate9 macOS 3 03-23-2013 06:43 AM
Can't find Digi core audio driver!! thebreaksnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2011 12:44 PM
Digi Core Audio Driver Uninstall ? TCLguy1 Pro Tools TDM Systems (Mac) 2 02-05-2006 08:12 PM
Digi ....Core Audio Driver archtop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-30-2003 07:30 AM
Bug in Digi Core Audio Driver? Driver update coming? mgbasinski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2003 08:59 PM
