Old 09-18-2013, 08:28 AM
Default super-slow export as files (11.0.2)
I'm getting extremely slow export times when using apple-shift-k on a 20 minute 5.1 file.
It takes more than 10 Minutes (!!) to apple-shift-k a 20-minute 5.1 file to a SATA drive on my system. Settings: 24bit, split-mono, 48k.
Same think under 10 takes less than a minute I think.
It takes longer to export the file than to bounce it
Frank.
EDIT: Sorry I have to correct myself. It actually takes more than 20 minutes to export a 20 minute file.
Old 09-18-2013, 08:41 AM
Drew Mazurek's Avatar
Default Re: super-slow export as files (11.0.2)
Session Specific?
I had an issue with Command Shift K yesterday, was causing a crash. Rebooted and it went away.
www.drewmazurek.com
Old 09-18-2013, 01:02 PM
Restarted multiple times. Makes no difference.
Did it from PT10. Worked just fine.
Frank.
Old 09-18-2013, 01:21 PM
Frank.
All sessions?
www.drewmazurek.com
Old 09-19-2013, 01:10 AM
Originally Posted by Drew Mazurek View Post
All sessions?
Haven't tried all sessions but it works fine in 10 from the identical session that is slow under 11.
Old 09-19-2013, 04:39 AM
That would be the first order of business. Is it isolated to one session or does it happen to all sessions and newly created sessions.
If not, then you could try making a new session and use Import Session Data to make a "new" version of your session to see if that clears it up.
www.drewmazurek.com
60 mins session on PT8 is super slow bobo mark Pro Tools TDM Systems (Mac) 3 01-06-2009 05:18 AM
super slow screen response sambista Pro Tools M-Powered (Win) 7 08-01-2006 09:05 PM
Super Slow Operations of PTLE abuwan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-10-2004 07:13 PM
Slow G4 Super Drive Mick F. Cantarella Pro Tools TDM Systems (Mac) 7 06-23-2002 08:53 PM
meters move super slow Blue Eyed Christ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-05-2000 11:40 PM
