Old 04-08-2007, 10:45 AM
jimmyz jimmyz is offline
Default Replacing Macbook Internal Drive with a 7200?
Hi there,
I am looking to upgrade my macbook's (not pro) internal drive to a 7200rpm 100-150G. Just now it is fitted with a 60G 5400rpm. This, for me, is just not big enough. I am worried though, as i hear that the 7200 drive will cause my computer to heat more than it already does (the macbook gets pretty hot with pro tools running...).
Anyone any experiece with this?
Thanks.
Old 04-08-2007, 10:47 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Replacing Macbook Internal Drive with a 7200?
A faster drive will generate more heat and take more power (less battery life).
Since you don't put audio on the system internal, a faster drive will not help much with most applications. You will boot faster but that is about all.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 04-08-2007, 11:10 AM
muzak13 muzak13 is offline
I ordered mine with a 7200RPM 100gig. Is it hot? Yes, indeed (kind of nice in the winter)…
Runs great but I have nothing to compare it to. I will say that my gig is as a designer and I was recently working on some billboards that ranged from 500Mb to a little over a Gig. Image Size is a notoriously demanding command in Photoshop. It can use up to 5 times the actual image size to complete an operation.
Using an external firewire as a scratch disk the laptop handled these files beautifully.
Part of that was the ability to read the command (Image Size) from the system disk quickly.
peace
MacBook Pro DuoCore 17" 2.16Ghz • OSX 10.4.9 •*2Gb RAM • MBox 2 Pro • ProTools 7.3.1cs3 • FW 800 w/ Express Card
Old 04-08-2007, 11:39 AM
Yes, it is how you work. If I needed to do a lot of swap space with my internal, I would get a faster drive. If I was editing audio or video, I would make sure I had a good external.
My view is the internal holds apps and system software. I store results elsewhere.
Park
Old 04-08-2007, 12:46 PM
Yes,
i suppose the ideal situation would be to have an external firewire drive for my audio and the internal drive be a bigger (100 G odd) but at 5600speed. Best of both worlds.
Just as i need the bigger internal drive for programs etc etc i figured i would be as well jumping up to a 7200.
I assume there are no problems with the bigger sized 5600 internal drives in the Macbook heat wise?
Apple sells them up to 160G.
Thanks for the speedy replies.
Jim.
What is the Gbps speed suppose to be on a 7200 rpm internal hard drive? [email protected] Pro Tools 10 6 12-24-2013 12:53 AM
Can my Macbook Pro have an internal 7200 SATA drive? soundboy35 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 07-07-2009 12:32 AM
macbook 6086 errors - internal drive? protein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-19-2007 09:09 AM
8 tracks analogue to MacBook internal drive? slowdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2007 04:20 PM
5400 or 7200 rpm for internal drive? sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-27-2006 10:41 PM
