Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-07-2007, 11:37 AM
jaykip jaykip is offline
Default setting up pro tools to read two different interfaces
I have been using a projectmix i/o and pro tools 7.3 for a while now and I was thinking about getting Firewire solo as well (for portability). How do I set everything up so I can use the PROJECTMIX I/O and the FIREWIRE SOLO interchangeably?
Old 04-08-2007, 07:44 PM
Grooveman JS Grooveman JS is offline
Default Re: setting up pro tools to read two different interfaces
Just install the driver for FW Solo. Connect it to your Mac & startup as per your other M-Audio devices; it should detect the device & you'll see the device icon under Applications/Utilities/Audio MIDI Setup. From hereon you can use either the ProjectMix or FW Solo but not both at the same time.
PowerBkG4 1.5GHz, 2GB RAM on v10.4.11/FW Ext Drive 300GB/PT-MP 7.4cs7/ProjectMix/FireWire1814/FW Driver v1.8.4-3/BlackBox v1.7-2/Axiom61/ProKeys88sx
Old 04-10-2007, 09:55 AM
Thank you.
Traditional Avid interfaces vs 3rd party interfaces aftermid Pro Tools 10 9 10-24-2012 01:12 PM
New Pro Tools HD Interfaces Escape 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-19-2010 08:17 AM
Can i run several interfaces with MP Pro Tools? Logic Pro Pro Tools M-Powered (Mac) 0 06-10-2007 12:49 PM
Need Help, setting up studio Please read! sanscosm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-06-2007 11:45 AM
interfaces for pro tools 7 Illl0lll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2006 11:26 PM
