Does my PSU need replacing?
Hi, I am in the process of setting up my new HD rig, last night I unpacked my brand new Control 24, I turned it on to check the mains (having read the manual which indicated that the C24 should be turned on before midi or audio interfaces), and was alarmed to discover a nasty popping noise at regular intervals, coupled with the 16 preamp LED's flashing in concert with the noise.
I had thought that the analog monitoring section would work by default, apparently not. I have not yet connected the C24 to my Mac, so is this odd behaviour some default state prior to software/firmware initialisation, or a dogdy PSU? Thanks |
Re: Does my PSU need replacing?
Sounds like it to me.
My C|24 exhibited this exact behavour last week. It was indeed my PSU. My original PSU with a big toroidal transformer was replaced (along with new fader cards) after it failed about 3 years ago with a revision "F" switching PSU. That worked perfectly until last week when I came into my studio and heard my 5.1 speakers and my big KRKs popping VERY LOUDLY once per second. I had no idea how long it had been going on, perhaps as long as since the previous evening when I went home. The LEDs were also barely flashing in rhythm with the pops and a faint clicking could be heard from the PSU. I first removed the PSU and cleaned and reseated all connections as this has sometimes worked for others with PSU problems, but to no avail. So I called Digi tech support at 8:30am PST and spoke with Eric who agreed that it sounded like the PSU had croaked. As I was a registered owner with a previously signed indemnity agreement (so I could do the work myself) he asked for a credit card number to insure the return of the defective PSU (which was not charged) and sent a new rev "H" PSU that afternoon via FedEx standard. It arrived the next day around noon along with two small bottles of DeOxit and ProGold. I removed the old PSU and popped in the new PSU which now works perfectly. I put the old PSU in the same box, used the Digi-supplied return label and dropped it off at FedEx that afternoon. Even though the PSU on the C|24 has been a huge headache for Digi, they continue to provide no cost replacements. Kudos, Digi!!
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Replacing the kit | goga | The Drum Room | 3 | 01-23-2011 07:35 AM |
Replacing OMF elements | efisch | Post - Surround - Video | 1 | 10-02-2009 03:22 PM |
replacing CPU question | Aussie Scott | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-29-2007 10:05 PM |
Replacing LE with TDM | Cliffy_Boy | Pro Tools TDM Systems (Mac) | 4 | 05-18-2005 08:55 AM |
replacing my 001 w/M-Box? | Paul_Wolf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-30-2002 05:20 PM |
