Old 07-24-2021, 01:23 AM
Franklyn Franklyn is offline
Default whats the best OSX for PT 2021.6
I'm still on 10.13.6 (and everything works fine) but I want to go to 10.14 or 10.15.
whats your recommendation?
I`m on a Mac pro (2013) btw.
thanx for advise.
Old 07-24-2021, 02:00 AM
bobo mark bobo mark is offline
Default Re: whats the best OSX for PT 2021.6
i have 2 Mac Pro 2013. running on both OS.. its just fine.. but i think 10.5 has more long run.
Regards
Bobo
Old 07-24-2021, 03:23 AM
JFreak JFreak is online now
Cstalina (in my opinion) is the best OS for trashcans, works very well and zero reason to upgrade to the Apple Silicon transition versions.
Old 07-24-2021, 05:45 AM
climber climber is offline
Trashcan, 64 gig, Catalina, 2021.6 runs great.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 07-24-2021, 08:51 AM
moogboy100 moogboy100 is offline
Mojave is the best, because it's the last OS still supporting the video engine (such as Quicktime Bounce with same as source for every video format). In fact it's the last OS before Apple started forcing developers to re-write/re-compile for 64 bit and now M1.
Bottom line, even PT 2021.6 is still trying to fully transition from 32-bit to 64-bit as required by Catalina (they had to ditch QuickTime components, ruining the Quicktime Bounce feature, which they still have not fully restored to full working condition). And Big Sur is optimized for M1 chips, but PT is not even close to running natively on M1, so much so that the video engine has literally been disabled for 2021.6 on M1 Macs!!!
Until PT comes out with native M1 support and a video engine that can bounce out same-as-source H264/H265, I'll be sticking to Intel/Mojave.
Of course if you NEVER use video, then Catalina is a pretty good bet too.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
Old 07-24-2021, 08:53 AM
As you said, it depends on your needs. Catalina got hardware side of transition done, but video is still unfinished. Mojave has video still allright, but performance is (relatively) bad.
Old 07-24-2021, 11:49 AM
kosmokrator kosmokrator is offline
Just finished a Dolby Atmos mix with apx. 300 tracks on 2021.6 HDX2 with hybrid engine using Catalina on new MacPro.
Amazing experience. The performance and stability was superb.
Old 07-26-2021, 11:03 AM
I was just about to upgrade to Catalina and then I saw this message. oh that's important to know, i use the bounce-to-video feature (to same as source) a lot. thank you for all of your advice.
Old 07-26-2021, 03:55 PM
lee52813 lee52813 is offline
Big Sur 11.4 seems more stable here, so mostly depending on the computer style. Mac Pro 2019 24 cores 96G Ram HDX2 and MTRX
Old 07-27-2021, 06:20 AM
peapodpost peapodpost is offline
Just updated my 2013 trashcan from Mojave to Catalina and am very pleasantly surprised. It could be the clean install itself, but Catalina seems to run PT 2021 better than Mojave was.
Downgrading from 2021.6 t0 2021.3 Mac M1 Leon77 Pro Tools 2 07-21-2021 09:43 AM
2021 TDM HD4 Win XP Sugarnutz Pro Tools TDM Systems (Win) 5 07-15-2021 12:34 PM
2021.3.1 innesireinar Pro Tools 80 04-22-2021 01:31 PM
Full Time Music Production "Jay Ohh Bees" whats yours and whats it like... WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2002 10:36 AM
