Old 06-16-2016, 09:34 AM
tamasdragon tamasdragon is offline
Default Re: Disk Cache in PT12 any opinion?
Do everyone use Disk Cache when you record also? When it was first introduced I heard that it can cause problems during multitrack recording.
my blog:Tamas Dragon
Old 06-16-2016, 09:36 AM
Drew Mazurek's Avatar
Use it all the time, including recording, never any issues.
www.drewmazurek.com
Old 06-16-2016, 09:49 AM
mlemos mlemos is offline
I just bought a new laptop with 24Gb or ram? Would I benefit from using disk cache?
Old 06-16-2016, 11:10 AM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
YES!!!
All the audio gets cached into a ram disk, which is really really fast, so playback and zooming and all things related to moving around playing stopping playing... the audio has just a small amount of lag if any... It makes for a easy experience, and no issues with large sessions (if you have enough ram and disc cache allocated) it just plays.
Just makes for a smoother more speedy working environment.
have a look in the manual about disk cache and see what to do, how to read the meter (is apart of system usage meter)
slow disks, full disks, fragmented disks, all become a non issue since the app reads all the audio files from this place while the session is loaded.
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 06-16-2016, 01:27 PM
Thanks for the info. I'll definitely give it a try.
Old 09-12-2017, 02:05 PM
moonwalker2 moonwalker2 is offline
Just want to ask what I should do here...
I just upgraded my computer and put in some 32gb of ram with a speed of 3200mhz. So they should be pretty fast.
I use alot of Kontakt lib's, how much would you say I should set pro tools to allocate for a session? 10 gb?
And if set to "normal", what does this exactly mean?
Cheers,
Old 09-12-2017, 02:57 PM
Cheers,
What problem are you trying to solve? Increase session size, # VI tracks? reduce session startup time? Fix specific AAE errors?
"Normal" means disk cache is pretty much off. You don't want that. Try setting that something around the size you expect a session audio might take (not the samples), at least a several GB since you likely have memory to burn (but watch out if you really are running huge number of memory hungry VIs, then the disk cache could harm performance).
The big thing with sample based VIs is the pre-load and streaming capabilities and settings in the VI. That is not related to the disk cache settings you are talking about. I'm not going to repeat that for Kontakt, you can look that up yourself. All that is separate from the Pro Tools disk cache.
If you want to reduce startup times, disk cache and pre-load of sample of all types may be harming more than helping. You should be looking at disk performance there, including using fast SSD drives.
Old 06-16-2018, 05:46 AM
chrismeraz chrismeraz is offline
What kind of improvements are you guys seeing with Disk Cache on? I suspect it's relatively useless on a high-powered computer with solid state drives (like mine). I allocated 16GB to Disk Cache and I see no difference yet.
I heard it's nice on a laptop though.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 15 05-09-2017 05:20 PM
Where's the Disk Cache sofakat Getting Started 12 06-27-2013 04:10 PM
Disk Cache Bug in PT 10.3.3 zion Pro Tools 10 51 03-12-2013 04:26 PM
PT10's Disk Cache or RAM Disk. Why not use the same concept for VI memory space? sunburst79 General Discussion 6 09-15-2011 11:28 AM
