Old 03-28-2014, 07:32 AM
romanoffski romanoffski is offline
Default Artist Control has no support for Logic X, or OSX Mavericks
I can't express enough how deeply disappointed I am with my Artist Control.
This piece of "gear" consistently crashes ever since I upgraded to Mavericks.
When it does work, its so slow that half the time Logic Pro X doesnt even register that a fader moved, or that a track was selected.
Don't even get me started on the touchscreen, which now does....nothing!
I've scoured the forums for months, nothing out there. Disabling Appnap didn't fix it, the new Eucon 3.1.2 has not had any improvements what so ever.
Why is it taking so long to have BASIC compatibility?
EUCON is what's crashing Logic Pro X and Pro Tools 100% of the time
PlugIn Path: /usr/local/lib/libEuCon2.dylib
PlugIn Identifier: libEuCon2.dylib
PlugIn Version: ??? (1)
Why has AVID abandoned us Mac users?
I sincerely hope the guys at AVID are reading these forums, and are actually considering fixing this awful mess.
Old 03-28-2014, 01:02 PM
8dB.co.uk 8dB.co.uk is offline
Default Re: Artist Control has no support for Logic X, or OSX Mavericks
Just taken delivery of an AC, and I'm blown away with it. Works fine with pt11 and 10. Really fast response and navigation. I wasn't expecting it to be this good to be honest. I know I'm running a different platform to you - it's such a shame that Apple have done their best to cripple Avid software and hardware, again...
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 03-28-2014, 01:14 PM
I can't and won't blame Apple for this, as the entire fault lies with Eucon software. Other manufacturers make controllers that work without issues.
The connectivity issue with Eucon existed long before Mavericks was even out.
I had issues on Snow Leopard even. But at least it worked 90% of the time back then. Now its totally useless. Instead of writing music i'm spending days figuring out how to get it to work!
Avid people, any ideas when we MAC users can expect a fix???
Old 03-28-2014, 02:19 PM
RyanC RyanC is offline
Did you disable app nap for eucontrol.app and the other one in there?
Old 03-28-2014, 02:26 PM
of course I disabled appnap, but unfortunately the problems are far worse than that. The AVID Artist Control surface simply isn't working in any capacity in Logic Pro X.
Sometimes I'm able to have fader control, but after a half-hour of working in a session, they drop, and freeze, while Eucon says it's still connected. Then the Library.Eucon extension crashes Logic.
Also if switching between applications while Eucon is working, will also cause it to crash.
I've assigned an IP address instead of having it on auto, like someone suggested earlier but it only made it more stable for about 15minutes, after which it went back to crashing.
I know I'm not the only one with these problems. Many fellow composers have abandoned the surface all together because of the major connectivity issues.
I'm hoping someone from AVID will chime in on this?
Old 03-28-2014, 03:18 PM
Check what Mavericks is doing to your network connection. From what I hear, people have taken days of tweaking various settings in Mavericks to get things even close to how they were before.
You can blame Apple for this. Other manufacturers have had trouble with Mavericks. Apple also make it very hard to "downgrade", even to a hardware level. Not Avid's fault.
Old 03-28-2014, 06:00 PM
francois_harel francois_harel is offline
On Maverick with Eucontrol 3.1.2...
I was unable to find how disable App Nap on eucontrol.app.
Even if I make Ctrl-I, it didn't show the checkbox to disable app nap.
I was able to disable appnap for PT HD 11 but not for eucontrol.app.
Why ?
iMAC i5 with 32Gb of ram and Promise J4+SSD
Sibelius Ultimate running PLAY using SO Plat+, SC_VOTA, HS Dia, RA, Silk, QLSV
Pro Tools HD Ultimate & Prism Lyra2
Old 03-29-2014, 12:28 PM
robertg robertg is offline
Run eucon version 2.6.2 and disable app nap.. It works.
Old 03-29-2014, 03:33 PM
Dear Robert,à
My PT HD 11 require EUCON3... and ask to install Eucon ver 3.
Old 03-30-2014, 11:04 PM
Can I even run Eucon 2.6.2 in Mavericks?
Disabling Appnap doesn't take care of the crashes. I've tried it all, believe me.
Perhaps its a network issue with Mavericks?
Still waiting and hoping to hear from AVID regarding this...
Avid Artist Control + Logic problems. matthihat Artist Series 4 02-03-2019 12:37 AM
Using Artist Series to Write MIDI Control in Logic megabraun Artist Series 3 03-03-2014 08:17 PM
Euphonix Artist Control doesn't work on Logic Pro X :( karhariasgr Artist Series 33 02-10-2014 01:56 AM
Artist Control makes Logic Arrange Window Jump rtcstudio Artist Series 0 05-10-2013 02:02 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
