Track Show / Hide issues with Session Data Import
I've noticed this for a while now and don't see a thread mentioning it. Any time I import session data that involves tracks that are inactive and hidden pro tools gets confused with their visual status and shows them. Usually I have to select one of the tracks that is visible but labeled as hidden and select show for things to be corrected. after doing that all the tracks hide as they should. Has anyone identified a conflict that causes this? I'm running OS 10.6.2 PT 8.0.3cs1 on a MacPro with 12GB of Ram. I just built a fresh OS three weeks ago to try and rule out my plugs / installs with some of the other beloved issues were seeing under 8.0.3
Thanks!
Luke Rohwer Acacia Recording & Production www.acaciarecording.com Luker[at]acaciarecording[dot]com Studio 301-703-0035 |
Re: Track Show / Hide issues with Session Data Import
I definitely wish that all hidden tracks in the session you're importing from, would come into the new session with some kind of flagging to let us know which tracks were hidden. or better still when you go to import session data from a track it identifies which tracks were hidden so we can choose not to import them!! I often have to load the original session that people send me just to check which tracks were actually in the edit window and being used. Chris
I'm with you regarding some kind of flagging or indicator post an import. Have you had issues with tracks that are technically inactive and hidden being visible after an import. When I click on their menu the status option says Show but I can already see them...
Yes any inactive and hidden tracks are NOT hidden when imported! We just need to be able to identify them before and after importing any hidden or inactive tracks. Chris
Correct but what I'm seeing are tracks that aren't hidden when Pro Tools thinks they are based upon the hide vs view option. I can see them but the option only allows me to view them instead of hid them. If I select view they hide.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
Yeah, this has been bothering me for a while as well. The tracks are visible although in the "Tracks" bin they are marked as hidden. Showing or hiding any track seems to kick PT back into gear. Super confusing at first though....
m |
yeah this is definitely broken
have to save and re-open to get the proper show/hide per track |
Can we fix this please??? Its been 2 years and I am tired of this!
+1
Please fix this.
www.highlakehill.be |
Import memory location: track show hide??? | audioluche | Pro Tools TDM Systems (Mac) | 2 | 01-20-2011 09:30 AM |
Pro Tools 8.1 IO issues with Import session data, please help | IshaErskine | Pro Tools TDM Systems (Mac) | 2 | 12-04-2010 07:13 PM |
Weird Track Show vs Hide while Importing Session Data in PT8 | acacia | Pro Tools TDM Systems (Mac) | 2 | 06-02-2009 01:54 AM |
7.4 HD to 8 LE to 7.3.1 HD Import Session Data Issues ? | mu-tron-kid | Pro Tools TDM Systems (Mac) | 0 | 04-09-2009 08:25 AM |
Import track color in import session data | deardaddy | Pro Tools TDM Systems (Mac) | 5 | 06-11-2007 06:35 PM |
