Old 03-24-2017, 07:39 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Protools Control App won't go past the login screen
Hey Justice - I don't see the Pro Tools | Control and EuControl product listed in either of the accounts using the email addresses referenced in your support case. Looks like at least the second new account you created hadn't been verified. Will follow up via support case to get more specific info.
linkedin
Old 03-24-2017, 08:49 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Thanks Jeffro, I responded to the support case email.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 04-04-2017, 09:54 AM
JCBigler's Avatar
I am happy to report that we have solved this issue.
It was not a network related issue, at least not directly.
When we sat down with all three iPads to look at all the settings, and see if any of them would work on any networks; one of them did work and was able to log into the Avid account and the Protools Control app. The other two still did not work even after being connected to different wifi networks that had different internet connections.
After going through all the settings, we noticed that the one that did work had the time zone set to Chicago, which is Central time, where we are located. The others were set to Cupertino. We changed the date and time settings to automatic, and walahh…They all were able to sign in to the Protools Control app.
We even sat down and changed the time zone back to test this, and we got the same behavior that we had before.
So, setting the time zone to the correct time zone for where you are located, or setting it to automatic seems to have fixed our problem. Even with usage restrictions turned on, and location services turned off, the Protools Control app works as long as the time zone is set correctly or to automatic.
Justice C. Bigler
Old 04-04-2017, 11:46 AM
jeffro's Avatar
Great news that you solved this, thanks for sharing your info. Mine defaulted to Cupertino (matches my network time), so I deleted the app, changed Time Zone to Chicago, downloaded the app again... it signed in and worked correctly. Even tried changing the Date, still no problem. I think it's worth adding to Support and Setup article though so I'll update that.
linkedin
Old 04-04-2017, 02:29 PM
JCBigler's Avatar
I went back and tried it again. I think once it installs and you get into the app the first time, then it works after that. Something with the Avid Account and the time zone setting caused it to hang on the initial login screen. It also did the same thing when trying to login to my.avid.com from a browser on the iPad. After time zone updated correctly, worked both ways, even after deleting and reinstalling the app.
Weird. But it's definitely something to check if you can't get it to login.
Justice C. Bigler
Pro Tools 10 won't get past loading screen rgp101 Pro Tools 10 7 06-05-2015 10:50 AM
Pt 11.1 will not load past splash screen Norrie macOS 15 01-15-2014 08:29 AM
New 27" imac Protools 8 Won't get past Xpand Adriel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-14-2009 02:41 PM
D-control Screen Igotsoul4u ICON & C|24 8 11-12-2004 09:10 AM
G4 D450 wont load past grey screen WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2001 12:04 AM
