Old 11-06-2010, 12:11 AM
textiles textiles is offline
Default "Protools could not initialize the current playback device"
Getting this every time I try to boot PT9 on my macbook pro without an interface. I could not find any drivers for the mac osx, and I tried every choice in the sound system preferences.
Hmmmm. Any suggestions?
Old 11-06-2010, 12:18 AM
Default Re: "Protools could not initialize the current playback device"
Previous thread:
http://duc.avid.com/showthread.php?t=285650
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-06-2010, 12:54 AM
Thanks for the link Rail. Yes trashing the audio preferences did it!
Seems to work fine now. Much appreciated.
Old 01-14-2011, 05:29 PM
johnwesleybarker johnwesleybarker is offline
Trashing the Audio Preferences
Can you be more specific?
Path>filename
...please
Old 02-12-2011, 01:12 AM
asantana asantana is offline
http://avid.custkb.com/avid/app/self...3=1078&Hilite=
Old 09-18-2011, 06:19 AM
Sevensmum Sevensmum is offline
check this out
http://everythingrecording.com/how-t...device-issues/
1. Launch Pro Tools 9
2. When the splash screen appears on the screen, hold down the “n” key on your keyboard, which will eventually open the Playback Engine dialog for Pro Tools.
3. At the top of this window, you will see the ‘Current Engine’ drop-down menu.
4. Choose a different Engine (such as Pro Tools Aggregate I/O)
5. Click OK.
This should allow Pro Tools to launch.
Mac OS X Only
If the solution above fails, you can try deleting the “com.apple.audio.AggregateDevices.plist” preference on Mac OS X. You can find this preference file in the following location:
* Macintosh HD > Library > Preferences
brill x
Old 12-02-2011, 04:06 PM
jusArapper jusArapper is offline
When Pt is starting hold down the "N" Key. Then select what you are going to play back with and.... Wallah! Worked great for me and didn't have to delete anything.
Old 02-25-2012, 01:29 AM
Apolllo Apolllo is offline
Thankyou, you saved me hours of frustration
Old 05-08-2012, 09:33 AM
studio4 studio4 is offline
Thank you so much. The "n" key did the trick. I am back up and running.
Thanks !
[IMG] code is Off
Fix #1 for "Protools could not initialize the current playback device" jamesb1t macOS 1 06-13-2012 10:21 AM
Pro Tools could not initialize the current playback device mkpascucci macOS 4 05-01-2012 04:00 PM
Protools cannot initialize current playback device......HELP!!!!! weedrock macOS 3 11-01-2011 07:47 AM
PT 9 won't start up: could not initialize current playback device edwinh Pro Tools 9 28 08-02-2011 03:16 PM
Pro Tools could not initialize the current playback device johnwesleybarker macOS 2 01-14-2011 05:52 PM
