Old 08-24-2006, 01:46 PM
swpowe swpowe is offline
Default change default fade length
So..I'm trying to figure out how to adjust the length of the fade that gets applied by pressing "apple+F". I don't see anything in prefs and we looking in the manual I find a section tittled "Auto Regions Fade In/Out Length" but I can't find that anywhere. How do I adjust this? it's driving me crazy. Thanks.
Old 08-24-2006, 03:33 PM
Starcrash Starcrash is offline
Default Re: change default fade length
Preferences>Editing>Default Fade Settings
Pascal Garneau | IMDb
Old 08-29-2006, 02:12 PM
Thanks for the reply. Unless I'm missing something...that isn't what I'm looking for. That will let me adjust the type of fade used but it has nothing about the length. It has the settings for pre and post roll for crossfades but doesn't let me change the length. Help..
Old 08-29-2006, 02:26 PM
Shawn Simpson Shawn Simpson is offline
If you're talking about doing batch fades across multiple region boundaries then it's adjustable in the lower right corner of the fades dialog. If you're making a single fade, just select across the region boundaries for the length of the fade before you hit apple+f (or just f if you're in command focus mode) and the length of the fade will be the selection, assuming the fade length is possible given the region overlap.
Hope that helps.
Setting of 'Edit Window Default Length' critictalk Tips & Tricks 1 07-30-2013 11:39 PM
Default selection length MFPBand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-30-2012 05:09 PM
Crossfade default length kje Pro Tools TDM Systems (Mac) 6 11-10-2010 08:50 PM
Edit window default length limit - why? trc229 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 09-21-2009 07:59 PM
Default Fade Peterjk Pro Tools TDM Systems (Mac) 1 02-07-2005 09:46 AM
