External Thunderbolt Drive?
Good morning,
I've been searching the DUC and web this morning to see if i could find an External Thunderbolt Drive that would work with my MacBook Pro running PT11. There is a lot of discussion but I haven't found a clear answer. Any help or direction would be appreciated. Thanks |
Re: External Thunderbolt Drive?
Thunderbolt is just a road. You need to have a fast enough car.
Find a drive that has at least 7200rpm drive in it (not a "green" one), or a modern SSD which has good transfer rates.
Thanks, I'm just hoping someone can share an off-the-shelf solution that's been working for them.
If you already have any external drives that connect via FireWire, I would just get the Apple Thunderbolt to FireWire Adapter, available from the Apple store, OWC, and for $29 at Amazon.
This is what I use on my iMac, with 3 FW drives connected. There are off the shelf Thunderbolt interface external drive enclosures, but to me they are still pretty pricey compared to the above solution. |
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
I agree that thunderbolt options are too pricey but if I had an extra $800 laying around, I would have the drobo 5D. It holds 5 SATA drives. However, I decided to try USB3 docks with fast SATA hard drives. I picked up 2 Newer Technology Voyager S3's for $38 each. They work great for me at a fraction of thunderbolt prices. If you decide to go the USB3 route, be careful of some of the cheaper ones. They will not allow the drives to spin down with inactivity. The S3 does spin down.
Current system: Pro Tools Studio annual Windows 10 Pro MSI home build 11th Gen Intel i7-11700K @ 3.60GHz 32g RAM, 6Tb SSD AVID Dock w/Android 10" Tablet IK Multimedia AXE I/O Behringer U-Phoria UMC1820 USB Audio Interface Bakerplace.net A place for Audio/Video Post Production. |
The reason you don't want drives that spin down is it's the drive that determines when inactivity occurs. So, you spend 15 minutes setting up for a track, the drive has stopped, and when you press "record" the drive has to come up to speed and you can lose data. Did I misread you or are you saying your drives do spin down?
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
No, I WANT them to spin down. Not necessarily after 15 minutes though. I have not had a drive spin down while in an active session yet. But, with the other interface that does not allow sleep, on of my 2tb drives was getting extremely hot because it was spinning 24/7. These are not server rated drives and will probably not stand up to that kind of abuse for long. My studio does not run 24/7 and when I shut down the session, I like my system to sleep also. With the voyager s3's, all is good.
Thunderbolt is overkill for an audio drive, as it doesn't need the speed and bandwidth. USB3 or firewire is fine.
For whoever mentioned the Drobo, their products ate RAID only, and JBOD is better for things like this. |
Pro Tools HD Thunderbolt Native box and External Display | TonyBuenger | Pro Tools HDX & HD Native Systems (Mac) | 15 | 10-27-2015 06:05 PM |
External Drive - SSD or Thunderbolt | jgiannis | Pro Tools 11 | 16 | 01-21-2014 08:11 AM |
Native Card vs Thunderbolt external | brickroadstudio | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-28-2012 01:17 AM |
using thunderbolt drive as a streaming drive | edencane | macOS | 7 | 05-11-2012 07:49 AM |
External Thunderbolt display Affecting performance on MBP Quad | EDurney | macOS | 4 | 12-13-2011 03:37 AM |
