ADR Take Counter
I need a separate numeric display counter that will increment every time PT goes into recorder. If the marker window could be made sizable and only to display the current marker, that could work as well. 3rd party programs like EditPrompt is way over kill and is a different work flow and is pricey Any programmers out there? I would pay Thanks |
Re: ADR Take Counter
I use BoomRecorder as a backup recorder. The added benefit is that it's scriptable. I send information to BoomRecorder at the same time as renaming the record track, then I pull info from the fields in BoomRecorder and then have it display on my screen when going into record.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
http://duc.avid.com/showthread.php?t=380506
While that post is in the right forum, this one is a double post, possibly a violation of the terms of use. "You will not post multiple identical postings (or 'cross post') in the same forum or more than one forum to solicit a response as this may be considered spam and removed"
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
The workflow I'm talking about, you need the following:
FastScripts BoomRecorder LargeLook Extra Suites Script relies on positioning (track show/hide and track heights). Mine looks like this... Memory locations and window configurations are "programmed" to reset the layout for the scripts to work properly. If you want to send me your ADR template, I can change my script to work with your session (hopefully).
Re: Take Counter Display ADR
Can you not just have the edit window on a screen - the region name increment not ok for you?
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
I was About to say, label your record track properly and you won't need it.
Sent from my D5803 using Tapatalk
Pro Tools Utimate 2018.7, on - i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB; Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB; "Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB. RME FireFace802 + ARC, RME Babyface Avid D-Command, Artist Control, V-Control, Korg MicroKontrol 7.1.2 Presonus Monitors |
It's beneficial for the director or other crew (who don't understand how Pro Tools works) to see a user-friendly take counter. See my responses in your other post regarding what you could do.
Here
Yeah. Label the record track with the abbreviation of the character and a cue # and PT will do the take numbers for you. Move on to the next cue, rename the record track with the new cue # and PT will take care of the take numbers. All for a nice price!
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Anyone else with counter changes? | albee1952 | Pro Tools 11 | 0 | 04-09-2015 08:03 AM |
Big Counter Bug | Shatzer | Pro Tools M-Powered (Win) | 0 | 04-21-2010 03:59 PM |
Main counter mode not switching using "counter" switch | bashville | ICON & C|24 | 2 | 08-07-2009 04:07 PM |
BPM counter from Logic | bobo mark | Pro Tools TDM Systems (Mac) | 1 | 10-31-2008 05:39 AM |
OT: BPM Counter for OSX? | Mike Czech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-20-2003 05:37 PM |
