Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 05-08-2010, 11:44 PM
Avid's Avatar
Avid Avid is offline
Administrator
Lightbulb VENUE D-Show 2.8.5 Console Software Update
You can download the 2.8.5 software update (for all systems running 2.8, 2.8.1, and 2.8.2) from the following page:
May 6, 2010
For VENUE D-Show®, VENUE Profile, VENUE Mix Rack, and VENUE SC48 Systems
D-Show 2.8.5 addresses issues discovered after the release of D-Show 2.8, and includes all fixes provided previously in D-Show 2.8.1 and D-Show 2.8.2. Affected VENUE systems running D-Show software version 2.8.x can be updated using the D-Show 2.8.5 update.
Please Note: VENUE systems running version 2.7 or earlier must first be upgraded to D-Show 2.8.1 before applying the D-Show 2.8.5 update. D-Show 2.8.1 Upgrade Kits are available for purchase from any VENUE reseller.
Who Should Use D-Show Console Software Version 2.8.5?
This update is recommended for all D-Show 2.8.x console software users and contains fixes in the following areas:
  • Plug-in processing
  • Snapshot crossfades
  • Device discovery
  • Personal Q
What's Fixed in Version 2.8.5?
The following issues are present in all previous versions of D-Show software 2.8.x, and are now fixed in version 2.8.5.
Fixed: Plug-in Noise issue (Item VSW-5077)
  • Inserting plug-ins in the Plug-ins Rack sometimes produces noise on the channels with plug-ins inserted, or causes audio to stop passing through the plug-in. This can happen, for example, when adding plug-ins to the Plug-ins Rack, when moving plug-ins between rack slots, or when loading a Show file.
  • The issue is limited to system configurations using 0, 8 or 16 Graphic EQs (GEQs), and is most likely to occur immediately after modifying the configuration of the Plug-ins Rack (including loading a Show file). There is little chance of encountering the issue during a performance; however, it could arise when switching Show files between bands (each with its own plug-ins rack), or during a rehearsal when the engineer is trying different plug-in configurations.
Fixed: Snapshot Crossfades can Cause the Console Fader Position to Show an Incorrect Value (Item VSW-5160)
  • When using crossfades to transition between snapshots, the console faders may show a different position than the actual value, which is shown on-screen. When this occurs, touching a fader may cause a noticeable jump in level.
Fixed: Lost Control Surface Components are Not Shown as Missing on the Options > Devices Tab (Item VSW-5158)
  • When a VENUE Profile console, VENUE D-Show Main or VENUE D-Show Sidecar is lost (such as during a power failure, or when the unit is turned off or disconnected from system) the unit remains visible on the Options > Devices tab instead of being shown as not connected.
Fixed: Blue “Controller Detected” LEDs in PQ View of the Outputs Page Fail to Illuminate when the System is Initially Powered Up (Item VSW-5752)
  • If the Personal Q Rack is connected when the system is initially powered on, any connected Personal Q Controllers will fail to report their "Controller Detected" status on the Outputs Page of the D-Show software. Power cycle the PQ Rack or hot plug the PQ Controllers to refresh the "Controller Detected" status.
Administrator
HTML code is On
VENUE 2.8.6 Console Software Update Avid Pro Mixing Support VENUE Live Sound Systems 0 04-04-2011 07:23 AM
VENUE D-Show 2.8.6 Console Software Update Avid Technical Alerts 0 03-25-2011 10:39 AM
VENUE 2.9.1 Console Software Update Avid VENUE Live Sound Systems 0 02-09-2011 02:31 PM
VENUE 2.9.1 Console Software Update Avid Technical Alerts 0 02-09-2011 02:28 PM
VENUE D-Show 2.8.1 Software Update for SC48 Avid VENUE Live Sound Systems 0 12-15-2009 09:47 AM
