PT9.0.3 SIGBUS crashes - EuCon to blame?
My system :
2.2ghz i7 Macbook Pro, 10.6.7, 4GB RAM Pro Tools 9.0.3 / EuControl 2.6.0 75358 Euphonix MC Mix Audio / libraries are on an external FW800 drive. My laptop is brand new, and I've been getting near constant crashes like this since my first day of using it, and installing PT9 and EuControl 2.6 - excerpts from a typical crash report : Quote:
I've been using the MC Mix for a few months, and I've also been seeing these crashes on two other systems I've used (my old 2.5ghz C2D 2008 Macbook Pro, and an older C2D iMac). The crash reports don't *always* point to a thread with Eucon references, but I'd say certainly the majority of times they do. I'm ruling out plugins, as I've tried editing with all of my third party plugs disabled using PT Plugin Manager, and I've still seen this error. No one thing seems to trigger it, but a favourite crash is when I route a bunch of tracks to a new aux input. However, I've even see it do this crash on save! (nasty!) I've already set the MC Mix to a static IP as per the user guide. Seemed better for a day or so, but it's started up again now. Any suggestions / help gratefully received! |
Re: PT9.0.3 SIGBUS crashes - EuCon to blame?
That sounds [bleep][bleep][bleep][bleep]ing annoying
My MC control is on it's way here in the mail I updated to PT9.0.3 today and I've been getting EUCON personality problems all day. For me, restarting fixes it for a while, but WTF? Things are pretty seemless in Nuendo. |
If you are saying that your audio and your sample libraries are on the same external drive, that could be the root cause of your problems. Put your samples either on the same drive with your OS or on a separate external drive. This may not solve all of your problems, but it will solve one definite problem...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Try trashing the 'com.euphonix' and 'com.eucon.' preferences files from MacHD>Library>Preferences and MacHD>Users>your account>Library>Prefences, restart and test again.
Also tell me what your network settings are - do you have Airport enabled? Is it the first item in the Network panel? Are you using a hub, switch or router? Any apps running in the background, especially ones that would use network/ethernet traffic? |
Pro Tools and Data Base Helper (use this insted of manual - highly recommended) -
http://www.jcdeshaies.com/
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
I've rolled Eucon back to 2.5.7, and gone back to using DHCP, but haven't had a sustained session with it yet. Will report findings. I have found that this combination (2.5.7 / latest firmware - sorry, haven't got the unit to hand - and DHCP) is resulting in much more reliable discovery of the unit, which is something. 2.6 always gave me an error and failed to add my unit automatically - I always had to go in and add it automatically. Quote:
When I myself search for malfuntion or errors I sometimes need help to see "the obvious", especially when your are trying for a longer period of time, like I get the impression that you have? Some versions back my setup crashed when I run iWeb at the same time, so perhaps you can list your setup and try to figure out if anything at all run (even in background - myself I have Air Display for iPad, a PCCard for 2xFirewireports, Timecapsule, Bluetooth, Airport, I run a Cinema Display screen with ext. HDD_USB in the back, 4 Ilok-keys on a switch), try to cover as many bases as you can if you want more precise input.
Also - I spoke too soon about 2.5.7. It still doesn't automatically add the MC Mix when I boot up - I have to do it manually after an error message. In terms of hardware, I have a FW800 drive attached, and at home I have a USB hub with a few drives attached and the iLok - but again, I've worked elsewhere with only the drive and the computer, and it's exactly the same. |
Didn't see this until I'd already posted on this. This is happening to me with Pro Tools HD 9.0.3. If I try to send a few tracks to an aux bus, it crashes out the system, and Eucon seems to be to blame (if the log reports mean anything).
Some sessions crash on opening. Others play but load SLOWLY. Then when bussing tracks PT crashes and Mac kernel panics. I've done the general PT troubleshooting and Euphonix pref trashing. These things would be great if they didn't bring my system down 5 out of 6 days a week.
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
I'd love to know how widespread a problem this is. With people using Pro Tools 9.0.x and the latest Mc Mixes and latest firmware.
I have a day or 2 to send these things back and get a refund. Seriously considering doing so until these bugs are ironed out. I know these forums only show the people having issues. But I'd love to know if there are people running crazy sessions 16 hrs a day 7 days a week without issues with this stuff. For me, in a few weeks, it's literally COST me money in comp time and downtime and corrupt sessions. not cool. I WANT to like them. But they've totally let me down.
EUCON, PT crashes after setting up PFL/AFL routing. | Audioartist | Artist Series | 2 | 03-26-2015 02:58 PM |
EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PR | dorothy | macOS | 12 | 12-07-2013 10:19 PM |
Exc_bad_access (sigbus) | basslik | macOS | 17 | 12-03-2013 08:04 AM |
eucon 3.0 crashes | tandri79 | Artist Series | 7 | 06-24-2013 01:24 PM |
Mc Transport Install/EUCon crashes [fixed] & other issues | Xill | Artist Series | 12 | 07-26-2011 03:56 PM |
