Old 10-07-2010, 10:29 AM
play4theworld play4theworld is offline
Default Sustain problems while recording MIDI
I was trying to record some piano stuff and I'm having problems with the sustain settings.
I don't have a pedal so i draw it into the control lane. I have to play the track as if I was listening to a recording (yet there is nothing there, it's just running through) in order to hear the sustain when I'm messing around trying to get things straight.
The real problem is that when I go to record, it draws that line back flat to 0.
Any ideas?
Old 10-08-2010, 12:57 AM
pianosound pianosound is offline
Default Re: Sustain problems while recording MIDI
Sounds like you need a pedal!! They are really cheap....... The only other way is to record, then add the pedal editing. Can you put the pedal editing on an aux track, and send the piano through that aux track to do final editing later?? I've never tried it, but use aux tracks for a lot of other things, it might have ped control? Check it out!
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 10-08-2010, 07:09 AM
Actually, it seems to work when i play like normal with the track armed then hit the record transport. I guess that will cause problems later on, I'll mess around with it.
Thanks
Problems with MIDI Sustain Pedal while recording ChrisSimon Pro Tools TDM Systems (Mac) 72 06-25-2014 10:30 AM
PT8, Sustain pedal, velocity problems while recording ChrisSimon MIDI 1 08-20-2009 05:23 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
sustain cuts out while recording midi tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-08-2007 05:29 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
