Old 04-03-2018, 03:40 PM
ReverbHead ReverbHead is offline
Default No EQ Display on 2nd Monitor
HI there,
I'm getting no EQ Display on my second monitor on my mix window. I have noticed that if I insert an EQ plugin and actually tweak any of the parameters the display shows.
Has anyone experienced this?
This is a MacBook Pro and the second display is a Samsung TV attached via HDMI.
Please see attached
FWIW I’m on the latest version of everything. OS, PT, Plugins, and what not.
File Type: jpg Screen Shot 2018-04-03 at 4.36.46 PM.jpg (78.6 KB, 0 views)
Old 04-04-2018, 05:04 AM
Default Re: No EQ Display on 2nd Monitor
Not all eq's work with this feature as I understand it; is the one you're trying to use supposed to work as intended?
Old 04-04-2018, 05:12 AM
Sardi Sardi is online now
The only insert I can make out from that image is Pro-Q 2. That should work with the EQ display feature. It definitely does on my end.
You make a point of specifically mentioning the second display. Does this mean the feature works if you open the mix window on your primary display? If so, I can’t possibly think of anything that would prevent that working on the secondary display.
Old 04-04-2018, 08:18 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
I'm not getting the EQ curve display in the mix window with any WAVES EQ.
Can anyone else confirm this behavior?
Old 04-04-2018, 10:50 AM
I don’t believe Waves support this feature currently.
Old 04-07-2018, 03:09 PM
Hi I think I wasn't clear enough. this is how it looks on my second monitor for channels with no eq inserted.
this is how it looks on my main monitor
i'm not referring to the eq plot reflecting a plugin, which I know that doesn't work for all plugins atm, i'm pointing out that a part of the GUI disappears on my 2nd monitor.
Thanks!
Tv monitor & pt display? weezamiah Tips & Tricks 9 01-22-2014 08:14 AM
monitor display studiojimi Pro Tools TDM Systems (Mac) 9 11-08-2011 04:11 PM
Display Monitor info Armando ICON & C|24 9 01-13-2005 10:14 PM
Display Monitor shady656 Pro Tools TDM Systems (Mac) 5 10-05-2004 07:06 PM
display monitor near 888/24 legativity Pro Tools TDM Systems (Mac) 1 09-13-2001 04:58 PM
