Old 06-03-2007, 05:10 AM
erant1 erant1 is offline
Default Out of CPU Resources
I am running a PT HD4 Accel (7.3.1) system on a Mac DP G4. Lots of power, and I never use up all of the available chips. Today I was attempting to bounce a mix to disk, and about 20 seconds prior to completion received a message that my CPU resources were too low, and that I should remove some RTAS plug-ins and try again. I did some internal mixes of tracks with RTAS plugs to new tracks and then deactivated the tracks with the RTAS plugs. I also looked at the CPU usage meter during playback, which showed almost no CPU use. I also have the hardware set to the highest level of CPU usage - 90%.
I ran the bounce to disk again, and received the same message, so I removed all of the remaining RTAS plugs - only two. Same message again, with no RTAS plugs running.
I'd appreciate any ideas on what may be causing this error message - is there potentially some other service that's consuming CPU resources? I have no other programs running concurrent with PT, and during playback the CPU meter continues to show very low usage.
Thanks!
CPU Resources Dallas002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-08-2006 08:43 AM
Help! DSP resources not enough! chanlon25 Pro Tools TDM Systems (Win) 3 07-12-2005 09:03 AM
More Great Resources!!! neomodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-01-2005 08:43 PM
Web Resources for Mixing? Daniel Poon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-05-2003 12:45 AM
web resources badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-13-2002 09:33 AM
