Old 04-28-2017, 02:12 PM
panamajack's Avatar
panamajack panamajack is offline
Default Re: Best video card for cheese grater Mac and HDX?
Originally Posted by johnnyv View Post
. . . I've ordered some of the convertors and Y cables mentioned above. . .
About the QSI converters:
Without the converters, I have two 3840x2160 running at 30Hz on a Radeon HD5870 (2010 12 core MP). Neither require a converter: one is hooked up DVI, the other by mini DP.
However, this has only worked with El Capitan: When I boot into Mountain Lion, I have only been able to get one monitor at 3840 x 2160 and the other at 2560x1440 (same monitors, same video card, same cables).
On an early 2015 MBP (running El Capitan), I can get 3840x2160 @ 60Hz from the TB ports, or 3840x2160 @ 30Hz from the HDMI (same monitors as on the 12 core).
Just an FYI for anyone lingering a while longer on ML.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 04-28-2017, 02:49 PM
johnnyv johnnyv is offline
Any idea what kind of success you'd have on Sierra?
Old 04-28-2017, 09:15 PM
panamajack's Avatar
I was digging around on the web and noticed people started playing around with 4K monitors about the time Mavericks was released. They were more pricey then.
With prices in the $275 to $400 category for the 28" variety 4K goodness, and compatibility with the early Mac Pro hardware, seems like now is a good time to gather a few 4K monitors.
I have been holding off on Sierra. But I would be surprised if there was a problem.
Apple updated the video drivers for El Capitan, which gave new life to the old 5870 cards. The 4K video drivers supporting multiple 4K monitors on the 5870 card may be in Mavericks or Yosemite as well (not tested). Can't imagine they would go backwards with Sierra.
Mountain Lion supports a 4K and a 2K, just not sure if a different card would enable 4K Plus 4K. Maybe.
Old 05-08-2017, 09:09 AM
djjazzy41 djjazzy41 is offline
Just for reference, the setup I mentioned in an earlier post is running just fine on Sierra. You can see the basic specs of my machine in my signature.
Originally Posted by The Egg: Be a Pro and stop being a Tool!
Mac Pro Rack (7,1) 16-core 3.2gHz Intel Xeon W
OSX Catalina (10.15.4)
8TB Mac OEM SSD System Drive
(3) 1Tb 7200rpm audio hard drives
192Gb RAM
Radeon Pro Vega II Video Card
2 Avid HDX Cards
2 Avid 8X8X8 HD I/Os; 2 Avid 16X16 HD I/Os
PT Ultimate 2020.3
Old 05-09-2017, 07:35 AM
K Roche's Avatar
K Roche K Roche is offline
so to clarify the Sapphire card you linked (out of stock right now hopefully it will come back in ) can go in the single bottom Pcie slot on my Mid 2010 Mac pro machine ( where the current video card is ) but needs the Y power adaptor ?
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #16
Old 05-09-2017, 09:18 AM
Yes; the video card is actually a double-slot card, but occupies the same space as the factory card. I installed mine in exactly the same location as the original Radeon card was installed. My machine is also a 2010 Mac Pro, and I used the Y cable I linked in the earlier post to connect to one power slot on the mother board and both power inputs on the card itself. The other power slot on the mother board was used to connect the power cable to my HDX card. I understand that there may be newer, more powerful cards out there that guys have used successfully, but I wanted one specifically approved and tested for the Mac, as I just needed one 4K display to run in conjunction with my Apple Cinema display. It has worked perfectly for what I needed. Hope this helps!
192Gb RAM
2 Avid HDX Cards
PT Ultimate 2020.3
  #17
Old 05-09-2017, 02:42 PM
K Roche's Avatar
Hey thanks, I have as per my sig PTHD native card and then the Samsung and PCIe card adaptor in the two slots above the Radeon so fitting into that slot is a requirement
System :
Enjoy the Journey
.... Kev...
A little Whine and Cheese... lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-20-2008 11:54 AM
I like cheese! Anyone got a plunger? c.evans Pro Tools TDM Systems (Mac) 8 10-20-2006 03:02 AM
Here comes the cheese.... 3JDamon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-14-2004 05:09 AM
Whine with my cheese? ladewd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-01-2003 11:53 AM
BEST CDRW to put in new Cheese Grater? Lee Blaske Pro Tools TDM Systems (Mac) 5 09-13-2002 09:05 PM
